i have all of my components selected, let me know what you think
uncomplientspud
i have all of my components selected, let me know what you think - 03.11.2008, 06:13 PM
alright guys i have a savage waiting to be converted and here is my list of what i want to run
FLM BL conversion chassis
BK 9920 car controller
feigao XL motor thinking of a 9? (please help me with what motor is the best to use)
i am going to be running 4s lipo most likely, but if you guys have opinions, let me hear them all, i want to know what you think of i what i have chosen
03.11.2008, 06:16 PM
5s would be a better choice with the 9920 and 9xl. You could run an 8xl with 4s lipo, but the extra voltage from the 5s will help move the heavy savage around. Plus the motor and esc will run cooler with 5s.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
03.12.2008, 12:48 AM
I would use something like the 10XL on 5s.
03.12.2008, 01:10 AM
The 9xl will be ok on 5s, nowhere near the 35k sweat spot.
zeropointbug
Z-Pinch racer
03.12.2008, 01:11 AM
Doesn't the savage weight in a tad more than a maxx or revo? If not, then sure a 9XL will do.
uncomplientspud
03.12.2008, 02:16 PM
i thought that the lower the number, the higher the kv rating
and the lower the torque
therefore on 5s:
8=35428rmp
9=31501 rmp
10=28356 rmp
so an 8xl motor on 5s sounds good, any one have experience with that motor setup?
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
03.12.2008, 05:00 PM
Not sure how you're doing your math but 5S lipo = 18.5, 10XL = 1668kv, so 30858 RPM is where you'll be at. Unless you are allowing for voltage drop, but then that's anyone's guess. I'd go with the 10XL for a savage. 8XL will be too hot at 38,000+ rpms. I use a 10XL in my emaxx and i'm real happy with it.
zeropointbug
Z-Pinch racer
03.12.2008, 05:01 PM
The higher the number, the higher the Kv. yes... but torque is not determined by the Kv. (the torque constant is; ex. oz-in./amp), all the XL motors have the same Peak torque. Then, however high of voltage you use, determines the max rpm, and thus the torque band (torque goes down linearly in the rpm range).
