New monster truck rules for world's fastest r/c challenge -
02.08.2008, 06:58 PM
Here are the new rules for MT's in this year's world's fastest r/c challenge. I figure a few of you guys here would be interested in these changes. Looks like no more wheely king touring cars allowed.
Tire size: Tires must have a minimum 130mm diameter and 70mm width. Foam tires are allowed. There is no rule regarding sidewall height.
Body type: Any body type that can be identified as a truck (stadium, pickup or SUV) is permitted. The wheels must be OUTSIDE the body, not tucked into fender wells or skirted.
i'm glad they made some changes, but i'd like to see a few more like suspension travel, ground clearence, and other things that'll identify it as a monster truck.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
Good news. I think there will be alot more entries this year, and no doubt half of them V-twins from the traxxas forum....
As for suspension travel & all, I think its best not to make those areas too regulated, since the best way to make an MT go fast is to slam it to the ground and tiptie the suspension, a la JonnyMaxxima style. I know what you mean though- I woud hate to see a 1/8 TC being passed off as an MT just because its got 40series roadrages mounted, lol.
It's good that they made some rules for the MT class to stop what happened last year, but I think they should have made the minimum tire width a few mm less, because LPR's might have been a good speed run tire (probably not as good as the phaltlines though), but mine are only 68mm wide, not 70mm, so they wouldn't be legal.
This is good news for the guys who will bring real trucks. I will see if Mike can have my chassis done before the event and I might run with a 1/8 scale truggy and a buggy. I have a company who is waiting for the chassis to be done so they can supply me with a couple of 22.2v 5000mAh packs.
Sweet ride you had last year John. Hope to make it this year. If the MMM comes out soon, I hope to run twins. I am actually building a second MRC like the one pictured below. It will run all rpm arms, steel tranny/diff gears, 40 series road rages out back, droped/stiffend suspension. It's 1/8 scale but hope to come in at 10lbs or better.
Does there have to be any "stock" element to this... I'm thinking FLM extended stampede chassis / Extended arms - with ceramic bearings - LARGE direct drive outrunner 400-500kv on 6S lipo - with 130 foam tires.
Is there anything about acceleration or rolling starts?
Differential Ratio: 1
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 1
Pinion Tooth Count: 1
Total Voltage: 22.2
Motor KV: 400
Tire Diameter (inches): 5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 1 : 1
Total Ratio: 1 : 1
Tire Circumference (inches): 15.71 inches (398.98 mm)
Total Motor Speed: 8880 RPM
Vehicle Speed: 132.09 mph (212.18 km/h)
Effective Speed Rate: 5.95 mph/V (9.56 kmh/V)
Estimated Adjusted Speed: 106 mph (171 km/h) - 19% loss
Effective KV Value: 400
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
I like the pede idea. Maybe use a small brushed motor with a airplane gearbox to a small wheel to get it all moving. Mount it on the back like a wheelie bar, you could even spring load it so that the torque of the motor holds it to the ground under power and when you let off it clears the ground. That way you could start the outrunner when it is moving, say around 5mph. That would cure the startup issues and whining when you win.
If you were to use a wheely bar, this could be built in to the center of it. Just a thought...
The only thing that might be a little hard is keeping it from lifting off. I only took my Stampede to 45MPH and if I gave it some more throttle it would start lifting off the ground.
