What pitch do I have???
Byte
What pitch do I have??? - 11.26.2008, 02:04 PM
Hi Guys,
I bought a Duratrax Vendetta, and I received a Align 430L brushless motor with it, but the problem is that the shaft from the motor is 3.16mm and the standard pinion from the Vendetta is like 2mm or something. So I searched for a 3.2mm pinion, and I saw one on this site, and the pitch of it is 32. But I don't know what pitch the standard pinion has, and I can't find something on the site.
So how can I measure the pitch of my pinion?
Thanks!
Serum
Serum's Avatar
11.26.2008, 02:06 PM
Have you got another RC you can compare it to?
You could simple put the pinion in the lathe and make it 3.2.
skellyo
skellyo's Avatar
11.26.2008, 02:08 PM
You need 1/8" bore 48P metric pinions for that motor in the Vendetta. Here's a large selection:
http://www3.towerhobbies.com/cgi-bin...ETRIC+PINION++
Byte
11.26.2008, 02:11 PM
Thank you!
I will buy some of those, hope they will fit
Thanks again!
- Patrick
@Serum, I could do that, But I think ll screw it up.. I'm not really good at that stuff, thank you anyway for your help.
Topic can be closed!
skellyo
skellyo's Avatar
11.26.2008, 02:13 PM
They'll work great. I used one in my Mini Quake with a motor that had a 1/8" (3.2mm) shaft.
