Upgraded Stampede VXL -
03.29.2008, 10:42 PM
This will be written in a few posts, as my pc keeps killing internet explorer, and I am sick of re-typing!
Anyways, I have done a few trades recently and ended up with a Pede vxl roller, neuenergy 5000 3s lipo and a Sidewinder esc. Figured that I would try out some of the unused motors in my "collection"! Going to stick with motors around 3500vk for this test.
My baseline is an old pede with an upgraded vxl tranny, revo style slipper, and full rpm treatment. This little guy has been beat up, and always come back for more. My favorite setup was a feigao 12s motor, 3s 4000 lipo and a mm. Gearing was 58/15, 32p. Runtimes ranged from 35-45mins, and it worked well, although the motor did get hot near the end. It never lost performance though! Ran it quite a bit and it was always very powerful, and good for mid 40s top speeds.
I pitted this against a vxl rustler and found that it was better than the stock traxxas brushless sytem, with the stock gearing, on 3s lipo. YOUR RESULTS MAY VARY, and I personally do not care how fast anyones emaxx goes with a vxl in it! Or how great the non-adjustable vxl esc is. Or that the feigao built traxxas motor is not built by feigao.
03.29.2008, 10:48 PM
First setup in the roller is a novak 13.5. It is the ribbed can version with the sintered rotor. Kv is 3300, according to novak's website. That must be unloaded, from my seat-of-the-pants meter.
First off it cogged badly with the stock sidewinder settings. I played around and almost cured it. Ended up with the punch control disabled, timing all the way up, and high start power. I have a feeling that with the 58/13 gearing I ran it was overgeared, as it lacked power and torque. The motor would most likely be better suited with 4s lipo, or in a lighter vehicle on 3s. Performace was not as good as the baseline, however temps and runtime was incredible. After about 20mins it pulled about 1700mah from the neu lipo. The motor was warm, and the sidewinder's temps had not changed.
Top speed was lower than the baseline. My main impression was that the motor did not like the gearing. I did directly solder the motor to the esc and that helped a bit with startup cogging. Just not enough power from the novak for me.
03.29.2008, 10:57 PM
Next up was an Aveox 36/15/1.5. This motor is similar in size to a s can feigao, but most likely compares to a neu 1506 in power output. Kv is 3700 according to the sticker. It has a 5mm shaft, so I had to switch to mod 1 gearing, as I do not have the correct 32p pinions in 5mm bore. Gearing is 46/11, slightly higher than the previos gearing with the novak.
Plenty of power, in fact too much. I did not change the settings in the Sidewinder, and can say that they can be dropped down a bit. It does need some punch control, as any fast throttle causes massive wheelies and back flips. The truck easily gets up to speed, which must be near 45mph.
What suprised me was the startup. This motor is constructed like a neu motor. The little Sidewinder had no issues smoothly starting this motor from standstill, even with my foot in the way. It is actually smoother than some of my feigao/mm combos!
Temps were a bit warmer on the esc, but the power output is more so that was expected. I will tone down the timing and add some punch control and run a full pack thru it to see how the temps do.
I am very happy with this setup. It easily outperforms the baseline. Almost too powerful!
Heres a few pics:
2 KiloWatt RACER
03.30.2008, 01:53 AM
Great that you are posting your motor results. So is the sidewinder more then you expected it to be?
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
03.30.2008, 12:52 PM
so im confused, you say that you do not like the vxl? besides the unprogramability of it i think it makes some excellent power, more than the rusty can really handle, and 72mph is more than fast enough for me
03.30.2008, 12:59 PM
So the aveox is a monster then?
Cool testing linc! This is great information.
03.30.2008, 01:11 PM
I am very happy with the sidewinder so far. I see no reason to use any other esc for 10th scale 2wd. I guess you would need something with more current capability if you are trying to do high speed runs, but for general use it works very well. I have a xxx-cr that I want to try a novak 3.5 on 2s lipo, and will use the sidewinder. Maybe it will have better luck in the lighter buggy with lower gearing.
I had a vxl rustler, and it ran hot. I had the stock gearing and a mamamps 3s 4000 lipo in it. The lipo was cool after the run, but the motor was very hot, and the esc was hot too. I was just not very impressed by it, compared to my feigao/mm combo. It did not seem as effecient as the runtime was quite a bit less. Plus the lack of programability was the main factor that I did not keep it. The mm is a superior esc, just would be nice if cc put a better motor with the combo.
Thanks, I try! Pity that aveox has quit selling rc motors. I picked all of my aveox motors up from their ebay sales, I must have 10 motors and they are all very well built. Plus I paid about 60-65 bucks each, so they were great deals. They seem to be comparable with the hacker c50, neu and lehner motors, and work very well in everything that I have tried them in. I have a 1300kv version of the next can length up, and plan to use it in a rustler on 9s. Should be interesting, to say the least
03.30.2008, 02:47 PM
hmm sucks about the velenion for you, i have the 5000 3s, and i run the whole pack which is about 30 mins and its definatly warm to hot, but not to the state of thermaling, thats also running stock gearing which is good for 56mph, bump it down a bit and it goes forever, but i agree about the mm, i have that in my revo and its awesome! i love plugging it into the computer, makes you feel like your doing surgery to it or something
03.30.2008, 02:52 PM
I may have had a bad example. The velineon seems to be a bit power hungry on 3s. I did not get that kind of speed out of my rustler. I will say that the feigao/mm setup had about the same power, but seemed to be more effecient. I would like to pit a vxl pede to the aveox powered one to see how it compares.
03.30.2008, 03:01 PM
at the track when im under 1/2 throttle most the time, i can get like 45 mins, out of my 5000, temps arent to bad either, so who knows maybe yours was a bad seed, im just glad mine isnt like that
03.30.2008, 03:19 PM
Yeah, it really is a disappointment that they stopped selling them. I remember their ESC and motor combo (the "RC7" motor). I had always wanted one of those bad boys when I first got into brushless. People ran emaxxes with that little motor in it!
I found a few places that still sell the motors, but it's hit or miss. Some are either super expensive (like, 260 bucks for the exact motor you used), or are super cheap, but not in stock.
03.30.2008, 03:31 PM
Oh, well, I am glad I got mine when I did. The most expensive aveox motor I bought was $125, and that was a 1515 size motor with 1200kv. Still a killer deal. I guess people did not know what the motors were? I think I paid 45-50 bucks for the pede motor, cheaper than a feigao l can, and it was brand new.
03.30.2008, 03:57 PM
Holy crap, 50 bucks! That's hilarious considering it's comparable to motors that are 3 times that amount, if not more.
03.30.2008, 11:54 PM
Certainly is! Those ebay auctions were a good find!
03.31.2008, 12:18 AM
Ran the truck again till the lvc kicked in. I got about 10mins, plus the other 2 runs, so it must be about 30mins total.
Ran well until the lvc kicked in, then it mysteriously stopped. I will examine this latter, maybe with a recharged pack!
All kidding aside it ran well. I will try to run a full pack thru it and see how the temps do.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
