Pushing the limit
Five-oh-joe
Pushing the limit - 04.30.2008, 01:35 AM
I've read numerous threads on pushing the mamba max ESC to its limits (and sometimes beyond!). But how many people have messed with other electronics like the Novaks or LRPs?
I was messing with my XBR/SS+ firmware Novak ESC, and just for fun, I hooked up a 3s lipo (only read about 10.58v according to my digital multimeter; it just came back from a run in my Trinity NOW). To my suprise, the ESC worked fine. I was going to test a fully charged 3s pack, but then I just took a quick look at the cap and it's only a 10v (I switched out the stock 16v one for the larger capacity 10v since it allows things to run far cooler).
So this brings me back to my point: does anyone know the limits of the Novak ESCs or any other manufacturer's ESC? I'm half tempted to push this ESC till it breaks, but I don't have the money to get a new unit afterwards.
04.30.2008, 10:00 AM
Just be aware that pushing the limits shortens component life. Higher voltage stresses the dialectrics of the components, even when not pulling any current.
Also, manufacturers figure in a safety margin (generally around 25% or more) for components selection. That 10v cap is designed to work on around 8v or less. 3s lipo will be 20% higher than the cap rating with no safety margin.
The MM uses 25v caps, which is perfect for 4s. 5s is pushing it, 6s is a def no-no.
And we are just talking about the caps here because it's easy to see their ratings. There are other components with max V ratings as well.
Five-oh-joe
04.30.2008, 05:29 PM
Hmmm. I see what you mean then there Brian. I'm guessing the FETs can probably deal with 3s lipo under a lighter load, but I know the cap is a no no (hence why I'm not trying it...).
I guess the only way to find out what the true max is of the ESC is to open it up and look up all the parts on digikey huh?
