Hydra 120 problem
KaztheMinotaur
KaztheMinotaur's Avatar
Hydra 120 problem - 06.17.2008, 10:27 AM
My Hydra 120 won't communicate with the Castle Link. When I first plug the Castle link in everything is green and I get a pop up saying that there is new device firmware available. When I click OK it starts to read the settings, briefly, and then stops. I then get an error message saying that it didn't get a response from the controller. It says to unplug the USB device and try again but that doesn't help. I try re-connecting the battery but that doesn't help either.
It won't arm with the radio either but I do have power to the servos via the CC BEC.
I ran it for a few minutes on Saturday evening. I later discovered that the battery probably has a bad cell.
Sammus
Sammus's Avatar
06.17.2008, 10:36 AM
I had the same symptoms with a ccBEC, turned out to be a hardware fault and I got it replaced. Try ringing the CC tech line.
KaztheMinotaur
06.17.2008, 11:06 AM
Tech guy says it is a problem with the processor and I should send it in for warranty repair. Does anyone know if replacing the RX plug will void the warranty?
He says they are 4 weeks out on repairs...
KaztheMinotaur
06.17.2008, 12:53 PM
I got it, and my whole kit, from Fine Design back in October. He is sending a new one out to me today. :)
06.17.2008, 12:56 PM
(gets back up off floor after falling down in disbelief) Wow, can't belive that you are getting service from CF. That is uncommon. Good luck!!!!
KaztheMinotaur
06.17.2008, 12:58 PM
