Mamba Max Heatsink
phatmonk
RC carbon junkie
phatmonk's Avatar
Mamba Max Heatsink - 06.19.2008, 05:34 PM
How do I remove the Mamba Max Heatsink.I will be putting a larger heatsink fastened with thermal epoxy.With this mod and a BEC and fan help to bring down temps on the MM.I am just wanting to run my 8T.It already have the BEC and fan.I need somethine to tide me over till I get my 2 MMM repaired.
06.19.2008, 06:12 PM
No need to change it - Mike runs 5s with BEC, Novak fan and a cap - thats it
phatmonk
RC carbon junkie
phatmonk's Avatar
06.19.2008, 06:28 PM
Where do I solder the HV Novak Cap.Should I make a splice and solder as close to the board on the power/battery wires?Is the Novak cap the HV cap?
06.20.2008, 05:08 PM
Yep and yep!
phatmonk
RC carbon junkie
phatmonk's Avatar
06.20.2008, 05:14 PM
Is there a way to remove the heatsink from the MM without damaging it.The summer temp now ranges from the upper 80s plus its gonna be a month till my Mamba Monsters will be fixed.
lutach
lutach's Avatar
06.20.2008, 05:39 PM
BrianG said in another thread to throw it in the freezer, but contact him before you do it.
06.20.2008, 05:45 PM
Yeah, I believe he said to put it in a freezer, then once the glue is nice and frozen, carefully slide an exacto blade in between the FETs and heatsink. Be very very careful not to rip up any FETs though as you do so....
phatmonk
RC carbon junkie
phatmonk's Avatar
06.22.2008, 04:34 PM
Wow this little MM realy rocks with the bec,fan.It was pretty hot here today.I ran 4s and my Tekno Neu 1515/1.5d/f and temps were 160f on the MM.The motor seemed to run cooler on the MM ESC compared to the MMM though I raised the BEC voltage to 6.0 volts more rpm on the novak fan.I allready have a 25mmX25mm magnetic levitation fan wired to go.It came no connectors.I did hammer a few crossup wheelies never full throttle though.
Fast5sRevo88
06.22.2008, 06:03 PM
Do u have to use a cap to run 4s?
azjc
06.22.2008, 06:07 PM
no..I run 4s in a BL Rustler using a CC external BEC with no fan and I have no heat problems and I am overgeared mostly to keep the wheelies in check and I am using a wheelie bar
