Emaxx racing, take out 2 speed setup?
Cain
Emaxx racing, take out 2 speed setup? - 05.23.2008, 12:54 PM
The emaxx I got had the 2 speed setup installed. I plan to race the vehicle, so I am thinking of taking this out and putting the one speed setup back in. Is it work doing for racing?
05.26.2008, 01:29 PM
During racing you dont really have time to think about shifting gears anyway, so it makes more sense to keep it as a single speed. A 2speed is only much good if you like to do low speed driving/crawling, have an underpowered motor, an outrunner that needs the lower ratio to get itself started turning, or an insanely overgeared high powered setup that needs the lower ratiom to get started too = high speed runs.
electric
electric's Avatar
05.30.2008, 10:55 PM
suicideneil explain what gears to take out of the e-maxx tranny to make it a make it a signal speed.
War Damn Eagle
05.31.2008, 11:46 AM
The 1st gear idler and output gear. Then just bolt the drivedog thing to the 2nd gear output gear and use 3 bearings as spacers where the 1st gear used to go (easy way). Or you can buy the Gorillamaxx setup- depends if you wanna do it the cheap way or nice looking way.
Cain
06.01.2008, 08:37 AM
I ran my emaxx this past weekend against truggies. Guys were excellent drivers, so I knew what to expect but the vehicle did really well. I was happy with it, and the single speed setup worked well.
Vehicle performed excellent till the stock traxxas servos decided to take a powder.
tha5150
tha5150's Avatar
07.07.2008, 02:54 PM
is there a pic showing how it should look when complete?
07.07.2008, 04:29 PM
To lighten the tranny a little, take your old 1st gear and cut away the plastic until you are just left with the hub. Then, use that as a spacer instead of the bearings.
tha5150
tha5150's Avatar
07.07.2008, 04:33 PM
brian, your man.. you know of a write up anywhere of how to convert a 3906 to 2nd gear only though? i need pics man.. lol..
tha5150
tha5150's Avatar
07.08.2008, 09:22 AM
guys, so so sorry, but i can NOT figure this out. call me what you will. but i was converting to my new FLM Extended Chassis lastnight and i could go no further when this task was at hand. if there is a completed pic or a write up on this, please send it my way!!!
07.08.2008, 05:54 PM
Numpty!
Anyway, I have some pics of my tranny when I was converting it to single speed- both the cheap version and full version. Take a look on my website for pics, should give you some idea of what to do:
http://www.robotwars.00server.com/txtproject.html
Pretend the coupler (silver thing) is the drive dog, and it is bolted/glued to the 2nd gear output gear in the same place. Then just remove the 1st gear idler (leave the shaft there though), and trim down the 1st gear output gear so that just the center is left to act as a spacer on the output shaft.
