Nomadio React questions
Nomadio React questions - 07.08.2008, 11:14 PM
Wondering if the battery voltage sensor would work for me? How high can it read, in relation to voltage?
Model number is nom-601
Thanks guys...
bl-is-future
bl-is-future's Avatar
07.09.2008, 08:22 AM
http://nomadio.net/docs/React_manual.doc This is the link for the manual. I read through the whole thing and it says nothing about a limit but i asked nomadio directly a while back and was told it is 20v max. Also instead of buying one for 2.50 all it is, is a male servo plug with only the + & - leads coming off. Hope that helped some at least.
VintageMA
VintageMA's Avatar
07.09.2008, 09:07 AM
I don't know if I buy the 20v max. I've used my voltage sensor on 6S lipo and it's read out the full 25.2 volts with no problems.
Like BL said - save yourself $20 and use a servo cable.
“Everyone has a right to be stupid; some people just abuse the privilege.”
07.09.2008, 09:48 AM
You guys are great...
Saved me some money! I also found the "voltage sensor" on ebay for $25 plus s/h!!!! I looked and almost expected to see rcwaffle selling it...
legobrains
07.09.2008, 12:53 PM
Sent support@nomadio.net this mourning and got a reply back allready
(I stole some of 'VintageMA' wording:)
ME:
Hello,
What is the maximum volt for the voltage sensor.
Cause I've used my voltage sensor on 6S lipo and it's read out the full 25.2 volts with no problems.
But I did not know if there was a max.
Thanks
Their reply:
I was told some time ago that it was 14 volts? It didn't hurt it reading 25?
Scott Lenz
Nomadio
2400 Market Street
Suite 13
Philadelphia, PA 19103
(215) 854-8432
So vintage MA, your sensor still works after you did that right?
07.09.2008, 01:30 PM
Interesting. I may or may not try it then...
Anyone have a spare battery door, I need one!
