track tested my truggy and brushless slash
rootar
rootar's Avatar
track tested my truggy and brushless slash - 06.28.2008, 11:36 PM
Well i tested out the truggy today on the track, i was running as hard as possible because id rather know now if something is gonna get to hot or go out on me, highest temps i saw all day (ran 4 packs through it) were 178* on the 10xl, 153* on the Mod1 MM, and 108* on the flightpower 5s. i got about 23-25 minutes of solid track time before i hit the cutoff of 16.5 volts. Im gonna try gearing up a tooth on the pinion as i think i was staying to high in the rpms, this should lower the motor temps, and ill have a fan (just in case) on the mm before the big race next weekend but if i can find the sweet spot with my gearing i should have a much cooler motor and about the same on the mm.
btw does anyone else have a problem with over jumping the hell out of even the biggest and longest jumps on the track? i had to let off on the two biggest jumps (both of which the nitros never back out of gas on).
I also picked up my slash today, i ran a couple packs thru it bone stock at the track and then when i got home i had a box from Mike with exactly what i needed, so the slash is setup like i had talked about in a previous thread with, 3s, mm, 9L, ccbec, mod1 gears, and the rc-monster heatsink clamp (which was a VERY tight fit), its geared for bout 45 mph. i made two spacers to go under the back of the battery hold down piece to lift it up for the 3s crapamps pack, and the bec is hiding under the mm and mount. cant wait to run this baby tomorrow.
also is a picture of badlands mounted on the slash only problem is youd need alot of body trimming or raise the body mount up a 1/2 inch
ID:	4883   Click image for larger version
ID:	4884   Click image for larger version
rootar
rootar's Avatar
06.29.2008, 12:05 AM
here are the rest of the pictures
ID:	4887   Click image for larger version
ID:	4888   Click image for larger version
Gee
A Horse's Ass
Gee's Avatar
06.29.2008, 01:04 AM
Looks cool. Let us know how it does. I didn't realize they (the slash) were that wide until I saw one in the LHS the other day. I had something smaller pictured in my mind.
rootar
rootar's Avatar
06.29.2008, 01:18 AM
yea the slash is all kinda huge looking but its still a lightweight underneath, i think mine weighs right at about 5 pounds rtr, i can already tell 2wd is gonna be two hands full and running over.....
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.29.2008, 02:34 AM
Slash is geared for 45mph, sweet, do you know if it was hitting that speed?
I have the same problem with jumps, nitro's barely make the jump and I go flying off the track, lol
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
06.29.2008, 02:35 AM
Far out, the chassis on the slash is really wide, could fit alot on there. What are those black things on the side of the chassis for? Keeping the body outwards?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
rootar
rootar's Avatar
06.29.2008, 09:31 AM
yea they hold the body out so you can really bang into each other when racing, they even have velcro on them and the body has matching strips to further keep in place and keep you from getting tanlged up, i havent driven the slash anywhere but my porch, and its raining right now but im sure itll have no problems hitting 45mph, its lighter than my LS10 and it pulled 45mph without breaking a sweat with the exact same setup.
skellyo
skellyo's Avatar
06.29.2008, 10:51 AM
You won't have velcro there very long. The velcro is stronger than the adhesive on the back of it. Mine was gone after running in the dirt and removing the body a couple of times.
rootar
rootar's Avatar
06.29.2008, 10:55 AM
your very right, mine come off the secind time i pull the body off, i replaced it with 3m industrial velcro
rootar
rootar's Avatar
06.29.2008, 03:24 PM
finally quit raining today and the dried up enough to run the slash some and WOW rolling 30mph wheelies are a piece of cake, i found it set alot better and didnt squat as much if you run 5/8" of preload collars on the rear and 3/16" preload collars in the front.
watching this scale looking truck do wheelies is just awesome, it jumps pretty good (nothing over 20 feet long and 4 feet high) so far but later in the week ill take it over to the big jumps.
i come back inside to trim just a tad more off the body i could hear it rubbing the rea tires when taking a sweeper under alot of throttle and i dont wanna tear the tires up like someone else already did. I also bumped up to a 13 tooth pinion instead of the 12 as my motor was running a little warm due too me not being able to control from going WOT all the time.
ill see if i can get a video here in a little bit.
brushlessboy16
brushlessboy16's Avatar
07.13.2008, 01:29 PM
have any pics of ur mod1 gear setup?
rootar
rootar's Avatar
07.13.2008, 01:36 PM
there is a picture of some one elses in that other thread about the best slash motor, mine looks the same.
brushlessboy16
07.13.2008, 01:38 PM
with mod1 gearing?
rootar
rootar's Avatar
07.13.2008, 03:40 PM
here ya go i snapped ya a pic of mine and here is the other pic i was talking about where it shows, mod1 installed, with 48 and 32p there for comparison. http://www.rc-monster.com/forum/show...t=13393&page=3
i know, i know, im about to start cleaning the slash in a few mins, but right now im building lazer zx5 diffs
