The Tekno RC Edition Neu Motors feature:
Larger 5x13x4mm bearings front and back
Sealed motor can
Rear end bell is safely secured by Neu's latest design, a must for any car application
Flat spot along length of shaft (no more grinding)
Industry standard easy to find 4mm bullet plugs installed
Cool blue anodizing and signature finned case lets your competition know you aren't messing around :)
A selection of winds will be available to suit 3, 4, 5, and 6s 1/8th scale buggy and truggy applications
These are genuine hand-built Neu motors, not mass produced
http://www.teknorc.com/product_info....24ad1441a767e0
Not just another 'conversion', the Tekno RC V3 Brushless Kit is a total electric transformation! Featuring the first commercially available 1/8th scale electric specific chassis along with Tekno RC's innovative patent pending Elektri-Clutch system. This is the kit everyone has been waiting for:
Factory Finish - hard anodized chassis, black anodized and injection molded components
4mm 7075-T6 CNC hard anodized chassis - only the best, no stamping here
No extra holes, no drilling, no mods - designed for electric racing by electric racers
Patent pending Elektri-Clutch system to tune the power delivery of the hottest brushless motors
Patent pending 1-piece motor mount/heatsink fully supports your motor and provides superior cooling under the most rigorous conditions. Need more cooling? Slap a 40mm fan on the integrated fan mount
Mechanical brakes with front/rear brake bias provides world class handling while lowering operating temps and easing the stress on your motor, ESC, and drivetrain
Optimized left-to-right and front-to-rear weight balance - battery is as close to center as possible for the best handling of any electric 1/8th scale on the market
Included radio tray keeps the wires neat and features an integrated transponder mount
Low CG battery tray keeps the battery protected while allowing the most height clearance of any setup on the market
Proven tough Tekno RC battery strap system WILL protect your batteries and will NOT break
Servo mounts feature integrated cable guides to keep your servo wires neat and away from hazardous moving parts
Includes full Tekno RC Elektri-Clutch setup - adapter, compact flywheel, collet, clutch nut, clutch shoes, clutch spring, clutch bell and bearings, an unbeatable value
Custom chassis mud guards keep the dirt away and finish off the factory quality kit
Tekno RC - No compromises!
Kit includes:
1/8th Scale Electric specific 4mm CNC machined and hard anodized 7075-T6 chassis
Patent pending motor mount (available for 36mm or 44mm motor diameters)
Complete Tekno RC Elektri-Clutch system - adapter, compact flywheel, collet, clutch nut, clutch shoes, clutch spring, 13t clutch bell and bearings
Low CG battery tray w/ battery straps
Radio tray w/ integrated transponder mount
Servo mounts w/ integrated wire guides
Chassis mud guards
Additional rear chassis brace
All necessary hardware
Detailed installation instructions
