Safe charging rate of a 4s 4800mah pack 25c
Safe charging rate of a 4s 4800mah pack 25c - 08.16.2008, 10:24 AM
Right now I am charging the batts. at 4 amps. Could I go as high as 5?
aqwut
Brushless Heavy Weight....
aqwut's Avatar
08.16.2008, 10:51 AM
you shouldn't have a problem... why not just charge @ 4.8 Amperes instead?
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
08.16.2008, 10:54 AM
I just want to be sure and not ruin a 130- battery. The batt. did not come w/safe charge rates on it so I have been charging it at 4 amps. I need to charge it today so i will up the amps.......thanks..
bl-is-future
bl-is-future's Avatar
08.16.2008, 11:34 AM
charge at 1c for all lipos except for high performance ones that specifically state you can charge at 2c. So your batt can charge at 4.8a max.
azjc
08.16.2008, 12:25 PM
you can charge a Flightpower pack at 2.5c if you wanted to but it shortens the pack life and it doesnt speed up the process that much
08.16.2008, 04:20 PM
Thanks for all your input guys! I will charge them @ 4.8 max.
tc3_racer_001
tc3_racer_001's Avatar
08.16.2008, 07:18 PM
anyone know what the max rate on zippy-r? they look to me like polyquest failures (didnt meet the 5000mah or voltage requirement) so techincally could probably do 2c? not about to try but just another usual hijack
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
azjc
08.16.2008, 09:27 PM
I would only charge those at 1c unless they say you can, I wouldnt try unless you would like to be the guinea pig
bl-is-future
08.17.2008, 11:29 AM
^^^ also make sure you record it in case we get some fireworks.
