Glitch And Twitch With A Cc Bec (help!)
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
Glitch And Twitch With A Cc Bec (help!) - 08.31.2008, 12:20 AM
Hi...
I need some advice regarding ridding my truck of the glitch 'effect' when I plug my CC BEC into the receiver... The effects are not immediate,
but when the truck rolls out to about 50 meters it goes crazy... The same thing will happen in the house when I am testing and it's only a
couple meters away. I tried plugging a receiver pack in just to see the difference... There was no glitch or twitch.
What can I do do to fix this problem? I am currently using two servos (steering and gear shift) with a Quark 125B.
Alien
Texas-Pete
Texas-Pete's Avatar
08.31.2008, 12:21 AM
What RX/TX are you using? Sometimes a lot of glitch is becuase of AM/FM TX's
My anti-drug: E-R-E-V-O
ANGRY-ALIEN
08.31.2008, 12:31 AM
Hey Texas-Pete, I'm still using the stock traxxas RX/TX (AM), But I only noticed the problem when I added this new BEC (the previous one blew up).
Texas-Pete
Texas-Pete's Avatar
08.31.2008, 12:44 AM
Welllll.... From what you described...
As your truck/truggy/buggy/etc rolls further away, the signal becomes a little bit weaker, allowing the BEC interference to become stronger . My guess is that the new BEC is giving off a stronger signal that is either greater than your old BEC, or that it is close to power wires... Try moving your antenna further away from the BEC/power wires.... Or try re-wiring your BEC, so that it's further away from your RX/Motors....
ANGRY-ALIEN
08.31.2008, 12:50 AM
Thanks Texas.. I'll try a couple combos and see how it goes.
