Can I use A123 7s2p with MMM v.3?
finfin
Can I use A123 7s2p with MMM v.3? - 11.08.2008, 04:22 AM
How many minute or hour for conclusion that MMM V.3 is pass?
Thank you for advance....
Basso
11.08.2008, 01:09 PM
It's less than 25V so it should be good
finfin
11.11.2008, 07:43 AM
thank you basso.
a123 = 3.6 x 7 = 25.2 volt
No others can answer my question, CC ?
satttheman
satttheman's Avatar
11.11.2008, 08:48 AM
you should be good thats about the same voltage as 6s lipo
Projects:
FLM Savage
RBMike
RBMike's Avatar
11.11.2008, 11:48 AM
I've run 6S A123 but not 7 yet.
Finnster
KillaHurtz
Finnster's Avatar
11.11.2008, 03:54 PM
At the very worst just charge to 95% (if your charger can do this.) The last voltage ramp up adds hardly any mah to the cells anyway, so if you stop @ ~3.5v/cell you are not really losing anything.
11.11.2008, 10:27 PM
6s lipo is 25.2 fresh off the charger (4.2v/cell). 7s A123 is also 25.2 fresh off the charger...as long as you use a typical CC/CV charge profile and not some "zip cord" charging method. So, it'll work...
lydiasdad
11.12.2008, 12:22 AM
plus as soon as you add throttle the voltage goes down. I also plan on running 7s2p a123 with the MMM.
