Tire question ?
E-fanatic
Brushless only!
E-fanatic's Avatar
Tire question ? - 11.21.2008, 05:19 PM
I picked up some losi super bolt-on tires and the foams that came with them are smashed on 1/2 of it(from packaging). So even letting them sit for a few days the foam didnt swell back up. I tried to install them but had huge flat spots in the tire b/c of it. So I was wondering what foam will work in these tires? They are 40 series , inside diameter is 3.7in (where the tire meets the rim) outside diameter is 6 inches (without tread) 6.4 inch with the tread
Any help would be greatly appreciated!
redshift
RC-Monster Square Tube
redshift's Avatar
11.21.2008, 05:31 PM
I highly recommend the Ofna molded foam inserts- www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCHofna+foam
Scroll down a bit, pretty sure your size is there.
E-fanatic
Brushless only!
E-fanatic's Avatar
11.21.2008, 05:47 PM
Well, I just tried putting the foams in the dryer on low heat for 15 mins and WOW they are almost brand new now. I cant belive it worked. So it looks like I wont need new foams after all!!!!!!!!!!!!!!!!
Matthew_Armeni
Matthew_Armeni's Avatar
11.21.2008, 06:11 PM
Another trick is to soak them in water, wring them out, and dry them.
  Send a message via AIM to Matthew_Armeni
blueb8llz
11.21.2008, 10:23 PM
those losi bolt ons are very good tires. theres a guy that swears by them along with the proline mulchers. and this guy has owned just about every popular tire.
what truck are you putting them on?
E-fanatic
Brushless only!
E-fanatic's Avatar
11.22.2008, 12:49 PM
I had a set of 40 series mulchers too. I just got finished balancing them. They are now spinning vey smooth. Now I just cant wait until the mmm/ combo shows up so I can run. I got the bolt-on tires b/c so many people around here have raved about them. So I figuired I would give them a try. I picked up some losi force rims to go with them. They look nice but the super long center cap bolts are a pain.
E-fanatic
Brushless only!
E-fanatic's Avatar
11.22.2008, 12:55 PM
here a few pics
blueb8llz
11.22.2008, 09:25 PM
wow those are huge. i like them rims too. arent you worried about your drivetrain esp with that all that power your gonna be using?
E-fanatic
Brushless only!
E-fanatic's Avatar
11.22.2008, 09:38 PM
The stock tire weighed in at 9 oz and the losi ones are 11oz. Not a huge weight difference. I do hope the diffs hold up to the extra weight and the power of the castle system. I do like the way it looks
jayjay283
jayjay283's Avatar
11.22.2008, 11:40 PM
those are some lawn munchers ..nice, look like a good winter option out here in Chi town
E-fanatic
Brushless only!
E-fanatic's Avatar
11.23.2008, 08:57 AM
Yeah Im sure that I will have a few bare spot in the yard from them. My britherinlaw is using my old mulchers so between the two of us I dont think I am going to have to mow(which is a good thing b/c I hate mowing)
