Radio help
Snowman 78
5,280 feet above sea level
Snowman 78's Avatar
Radio help - 01.09.2009, 10:21 PM
Can a radio lose a channel?
I have a 3PM, I wanted to use it in my CRT.5. I hooked everything up and the steering servo would not work. (I though I had a bed receiver) so I got a new receive and I am having the same problem. Channel 1 on both receives do not work. I am using a new servo and a RX pack to do the testing. When I hook the servo to channel 2 or 3 it works fine (with each receiver) but channel 1 won’t work. I check all the setting on the radio and they are good.
Thanks for your help.
Brushless Rustler
AX10
Venom Creeper
Slash 2WD
Slash 4WD
jhautz
jhautz's Avatar
01.09.2009, 10:50 PM
I havent ever heard of that one, but I suppose anything is possible.
I dont know if that radio has channel mixing on it or not, but if it does you could possibly mix the steering channel and the Aux channel and plug the servo into the Aux channel. It should work for a short term work around untill you can get it fixed or replaced.
to make it...
or break it...
Silent...But Deadly
Snowman 78
Snowman 78's Avatar
01.09.2009, 10:55 PM
It does have mixing I may try that. I would like to make sure both receives are good but I don't have any other FM radio.
Brushless Rustler
AX10
Venom Creeper
Slash 2WD
Slash 4WD
01.09.2009, 11:23 PM
Is the ch 1 on in the radio....some radios allow you to turn off channels
Snowman 78
Snowman 78's Avatar
01.09.2009, 11:30 PM
I don't think you can turn off any of the ch's on the 3PM but I did double check
Brushless Rustler
AX10
Venom Creeper
Slash 2WD
Slash 4WD
