foam inserts. what do i do?
Ryu James
Ryu James's Avatar
foam inserts. what do i do? - 01.13.2009, 10:40 PM
can anyone please tell me what to do when you get a tire and foam insert setup like these panthers? do you cut the foam? doesnt that make your tire off-balance? i have only had tires with molded foam inserts that fit perfectly into the tire. what do i do with this thing?
foaminsert
Jammin SCRT10 Neu 1512 1y
01.13.2009, 10:43 PM
open it up and shove it in. if there are fitment issues it can be trimmed(squish it down with a straight edge and cut with a sharp razor blade to keep from getting off balance).
the more foam that's in there, the less likely the tire is to balloon.
Ryu James
Ryu James's Avatar
01.13.2009, 11:30 PM
amain says that the Panther 2.0 switch tires fit 38 series wheels like the proline LPR. i thought 38 series was the revo 3.8" wheel and LPRs are 3.7". has anyone tried the panther tires on a set of proline LPRs and do they fit snug?
