Brushless Supervader
eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
Brushless Supervader - 12.18.2008, 08:42 PM
I'm starting this thread for my next project. I am getting the MMM combo for xmas, and so I have my old electrical system with nowhere to go but in my evader! I'm going to cram a Fiegao 8L motor, mamba max and 5s protek lipo in this thing. My plan so far is to use the stock transmission, with a mod 1 spur and pinion set. I forget what count the spur is, since Im getting it off a friend, but the pinion is 10t. If worse comes to worse and the motor will not fit, I will make a custom aluminum plate/motor mount for the extra space. Since I realized that it wasn't the smartest thing leaving the 8l hanging off the back where its subject to all sorts of abuse(wheelies!) I am using a 1/8" thick 2 inch wide piece of flatstock that will be bolted to the chassis from underneath the evader, and will be bent up past the back of the 8l and past the front of the bulkhead to keep everything nice and safe. using the speed calculator, my top speed will be 51mph! All I need is about 20 inches of 2 inch flatstock, 1/8th inch thick. everything else, I have
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
