Slash 4x4 owners...diff fluid suggestions
Slash 4x4 owners...diff fluid suggestions - 10.02.2010, 01:18 PM
I am building my slash 4x4 and was wondering what diff oil you all are running. No racing for me...just bashing
I will be running a center diff as well
Semi Pro
Semi Pro's Avatar
10.02.2010, 04:38 PM
for bashing 250k center, 150k front,30k rear is fun
10.03.2010, 12:29 AM
why so thick fluids?
Off topic...anyone have to shim diffs and if so, what washers
nitrostarter
nitrostarter's Avatar
10.03.2010, 01:41 AM
Watch the Traxxas center diffs. The 2 I had were wobbly...
I ran 10K in front, 20K in center, and 5K in rear. I liked this setup for bashing it and racing. I pretty much followed Slayden's race setup minus swaybars.
N. Rustler conversion
Team Pie 420
The Dude
10.03.2010, 04:57 AM
30k front 7k rear 100K center with FLM alu center diff and bearing kit.
with a MMM 2650 and 2 turnigy 5000 MAH 20c in series gets me great 25+ run times bashing and is great fun imo.
Semi Pro
Semi Pro's Avatar
10.03.2010, 05:52 AM
because of the 2 spider diffs
10.03.2010, 08:56 AM
still unsure of your answer. There seems to be a bit more play in the pinion gear than I normally run on my truggy. I am only going to run a 3s set up max
10.03.2010, 09:08 AM
What did you use for gearing?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.03.2010, 12:06 PM
10K F, 100K C, 7K R for my offroad track set up.
nitrostarter
10.03.2010, 12:24 PM
was running a neu 1509/1Y on 2s. geared 16/52.
slimthelineman
slimthelineman's Avatar
10.03.2010, 12:45 PM
I run 10/30,000/10 on my 3s race setup and has worked well for about a year on multiple tracks and some occasional front yard test runs. Depending on your motor choice you might want to go thicker in the center. I run a 550 and the 30k works well. Any larger of a motor I would use 50k+.
10.03.2010, 12:55 PM
I plan on running a Tekin 2650 motor on 3s or one of the new Tekin SC4 motors when they come out so maybe 50K fluid would be a better choice
