More power supply help...
Metallover
RC-Monster Spudgunner
Metallover's Avatar
More power supply help... - 03.21.2009, 09:59 PM
I had a charger that charged my old lead acid batts I use. I soldered deans onto it. The deans plug was backwards. Now when I plug it in the tiny green led flashes very fast. I took it apart and I couldn't find anything obvious wrong with it.
Today I came across a new power supply for an old laptop. It puts out 18v instead of 29v. I want to use this new power supply to charge my two 12v lead acid batteries.
The two things I think I need to do are put a charge limit on the system and change the voltage to something like 15v or preferably ~29v. Anyone know how I could do this?
Left is back of old ps, middle is ne, and right is insides of old.
eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
03.21.2009, 11:25 PM
The middle would not be very effective for your Pb batteries, because it only puts out 2.23A@18v. Most Pb batts can be charged at least at 6 amps
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
Metallover
Metallover's Avatar
03.21.2009, 11:28 PM
I just need something to charge my leads with. The other charger puts out 2.5 amps... It is kind of like charging a phone. You just plug it in all day then keep an eye on it too.
03.21.2009, 11:30 PM
What charger do you run with a pair of pb batts?
