soldering question
makana59
makana59's Avatar
soldering question - 01.11.2006, 03:32 AM
Hey guy,
I was just wondering if it mattered if I solder the BL motor to the speed controller directly or if I use a set of deans connector. Does it make a differnce in the connection? Will it be better to just solder it straight. I guess Im just thinking of maintence and stuff in the future. Easier to just use connectors when I have to remove something under it or something like that. If I use dean connector is this bad? Go straight or deans? Mahalos again for the help guys. Makana
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
01.11.2006, 04:33 AM
I soldered all my motors directly to the controllers. I think that is how most people here do it as well. I think it has something to do with getting more current to run through the wires and by having deans, you lose a little throgh them. But I'm not the expert, just thought I'd tell you how I run mine.:)
Basketti
01.11.2006, 04:55 AM
Yeah i heard you lose a bit of power, but if you do want to use connectors use the gold connectors.
dabid
01.11.2006, 04:03 PM
Lose a bit of power with what? Deans are the best out there for darn near everything, but the gold plugs would be more convenient because Deans are only 2 pole.
squeeforever
squeeforever's Avatar
01.11.2006, 07:11 PM
actually the gold bullet connectors are better because they are rated for 75 amps for 3.5mms and 150 for the 5.5s i think while deans are only rated for 45 i think.
Basketti
01.11.2006, 07:33 PM
I think you lose more power cause of the resistance in the plugs.
makana59
makana59's Avatar
01.11.2006, 09:05 PM
thanks for all the input guys.. I guess to be safe Ill just solder it stright together. Laters
MetalMan
MetalMan's Avatar
01.11.2006, 10:01 PM
FMA rates the Deans plugs at 60amps, but it is rather obvious that larger amp spikes are more than possible... Schulze rates their 3.5mm plugs at 85amps.
