Medusa Research
petewalford17
Wink Medusa Research - 04.09.2009, 01:48 PM
hi what Medusa Research motor can go in a emaxx i want atlest 45mph out of it more if possible also what gearing
thanks
if it dont go fast chuck more money at it
04.09.2009, 02:00 PM
I would say that a 70mm would be the best bet for an emaxx. Something around 2000-2200kv. Not sure on the gearing, use the gear calc by briang.
petewalford17
04.09.2009, 02:04 PM
castil 2200kv or MedUsa 2200kv 70mm
04.09.2009, 02:36 PM
I would go with the Castle motor myself.
petewalford17
04.09.2009, 03:02 PM
just got my self a Castle 2200kv what gering do i need
killermmn
killermmn's Avatar
04.09.2009, 05:56 PM
22 to 25 pion!!
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
04.09.2009, 06:23 PM
I have medusa 70-2300. I used 22/62 for 40-42 mph and 24/58 gor 48-50 mph
temp 120-150f
2x2s 5200mah
mmm
here 24/58 gearing video http://www.youtube.com/watch?v=s7gGZSHoS2k
MMM v1 zippy 2x3s 5000mah neu 1y 1/8 diff's
MMM v3 Rc-monster 2x2s 5200mah-HC medusa 36-70-2300kv
Pic's - video - youtube video's
04.09.2009, 09:06 PM
Pete- Use the calculator, it is your friend & greatest tool known to man & noob-kind:
http://www.scriptasylum.com/rc_speed/_top_speed.html
Enter the values according to your desired setup; model, voltage, motor kv etc, and it will spit out results based on what you input, its very simple to use.
For example, you want ~45mph on the emaxx 3905 (?) with 2x2s lipo(?), in which case:
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.8333333333333334
Other Ratio: 1
Spur Tooth Count: 65
Pinion Tooth Count: 24
Total Voltage: 14.8
Motor KV: 2200
Tire Diameter (inches): 5.9
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.71 : 1
Total Ratio: 14.13194 : 1
Tire Circumference (inches): 18.54 inches (470.8 mm)
Total Motor Speed: 32560 RPM
Vehicle Speed: 40.44 mph (64.96 km/h)
Effective KV Value: 2200
That would be a solid and sensible setup, with room for adjustment.
Choosing decent lipos and tweaking the esc settings will make all the difference for good temps, long runtime and best performance.
