Motor questions...
eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
Motor questions... - 05.10.2009, 03:57 PM
So my fiegao 8L finally did itself in :( Just as I was about to race my rustler too! So my question is, does anybody have some suggestions on a brushless motor to use for the rustler? I'd like to run either 2s or 3s in it(preferably a 2s hardcase), so I just want to find the ideal motor for racing. I've tried the CM5700 too, but they just dont mix well with the rustler.
Any suggestions?
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
05.10.2009, 04:17 PM
Neu 1506, medusa 50mm, or vxl. Ive got a vxl motor and mm esc FS!
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
05.10.2009, 04:25 PM
Get a medusa, a 50mm should do just fine as one pushes my CRT.5 around with ease and runs very cool, a 60mm would fit and not be stressed at all.
scarletboa
scarletboa's Avatar
05.10.2009, 05:02 PM
believe it or not, those ezrun motors aren't half bad. they have the same sizr rotor as the MM motors. the cans are finned though and the motors are lower kv, so they run much cooler. i'm getting the 3300kv one for my rustler vxl. (i dented my vxl motor)
eovnu87435ds
05.10.2009, 07:46 PM
bl_rvo and e-revonut, Medusa doesn't sound half bad. I was looking at their 36mm x 50mm 2200Kv motor with the 5mm shaft If I go 3s, and the same in 4800kv if I go 2s. That sound right? and does anybody happen to have one used?
scarletboa: do you have any links to those motors? and how did you dent your motor??
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
brushlessboy16
brushlessboy16's Avatar
05.10.2009, 07:47 PM
4800 is wayy too high of a Kv. try a lower one so you can use the standard sized pinions we already have.
Try something around a 3300.
asheck
05.10.2009, 07:58 PM
I think if he was planning on just running 2s the 4800 would be fine. But agree that the 3300 would be the best for 3s. I wouldn't go with the 2200 unless I was going 4s.
eovnu87435ds
05.10.2009, 09:06 PM
I was running 3s with the fiegao (3072Kv) and that was quite fast, so that was the only real reason I was thinking of the 2200 over the 3300. I am wanting around 30-35 mph for racing(seems good enough for 10th scale class). here's what I came up with using brian's speedcalc:
2200: 3s, 12/44 - 29.06mph
3300: 3s, 10/44 - 36.32mph
3300: 2s, 13/44 - 31.48mph
4800: 2s, 10/44 - 35.70mph
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
Metallover
RC-Monster Spudgunner
Metallover's Avatar
05.10.2009, 09:13 PM
Medusa 3300, 3s, gear up
4s for speed runs if you wish
that should be about right
If you want you could probably even bump up to the medusa 4200
eovnu87435ds
05.10.2009, 09:24 PM
Now I'm just worried about how much room I will have in the rustler to slide the motor around. I don't want to be locked into one gearing either... I guess I should have enough though. Ben's castle neu 2200kv is 41.78mm, and just barely fits in there, so is it safe to say I can change the gearing by one or 2 teeth on the pinion?
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
nitrostarter
nitrostarter's Avatar
05.10.2009, 10:20 PM
The castle neu is also larger in diameter than a 36mmX50mm medusa. You should have plenty of room to slide it around.
My vote also goes for the Medusa 3300 version. Plenty of power on 2s as well as 3s/4s speed runs.
N. Rustler conversion
