Best CV Driveshaft ???
flo65
Best CV Driveshaft ??? - 07.16.2009, 10:02 AM
Hello
I need your help !
Which are the best CVDriveshaft for T-max/Revo 3.3?
it's for my FLM-Maxx with 5/6s lipo
Traxxas ?
Tsais T-Bonz ?
MIP ?
RD Logics ?
I hesitate between TSAIS and TRAXXAS ...
Thanks
Bye
m.i.p for me
chrismechanic
m.i.p for me - 07.16.2009, 01:25 PM
hi flo65/all...well the traxxas ones look great but i have never used them, but i can tell you my 3906 e-maxx ive had for 8 years,
ive allways used the m.i.p shafts, in the last 8 years they have had one rebuild kit (barrel and pin) the drive cups have never worn out, the shafts will bend if you crash bad which is better than them snapping, cause you can run a bent shaft but not a broken one.
hammer and a vice will solve the bent shaft.
hope this helps.
chris
rhylsadar
rhylsadar's Avatar
07.17.2009, 09:55 AM
hi
imo the plastic driveshafts are one reason for the relatively few problems of the diff in the new maxx or revos. they can flex a little under strong abuse and absorb some of the impact energy. maybe the the new summit driveshafts are even stronger.
i personally would go with the stockers or summit like driveshafts. they are cheap and easy to replace if needed too.
bye
rhylsadar
______________________
Exercitatio artem paravit
rhylsadar at youtube
flo65
07.17.2009, 10:01 AM
You have the drive shaft for Summit ???
it is not the same as for the Revo?
nitrostarter
nitrostarter's Avatar
07.17.2009, 10:04 AM
I found the Traxxas Driveshafts to be well built and good quality. Plus they are chrome and come with pretty blue boots... LOL But they are nice and the fit is perfect. They are pretty strong and resisted bending to my basher abilities.
I have used MIP's in the past and have a set coming for my Rustler. Their quality is always great and they are pretty strong. I have bent some of these although.
N. Rustler conversion
rhylsadar
rhylsadar's Avatar
07.17.2009, 10:26 AM
http://www.traxxas.com/support/kb_se...cat=143&id=620
here they have changed the shafts on e revo to summit shafts.
i guess they should fit on other revos/maxxs shouldn't they?
bye
rhylsadar
flo65
07.17.2009, 11:16 AM
Oh yes !
indeed, they are different. They seem stronger !
