Medusa 36-50mm 3300kv questions
iTz Nicholas
Talking Medusa 36-50mm 3300kv questions - 07.05.2009, 11:26 AM
I'm going to get a Medusa 36-50mm 3300kv motor to use in a Hyper STe. On www.medusaproducts.com and they also sell the 36-50mm with one if their heatsinks permanatly attached. It is only a few dollars more so should I get that or get the normal version and use a different heatsink?
Motor Specs
MR-036-050-XXXXV2H-5
** Increased cooling over a slip-on heatsink.
** No air gaps to reduce effectiveness.
* *Permanently attached, will not move or slip.
* *39mm long heatsink, 48mm outside diameter.
"You can kill the revolutionary, but you can't kill the revolution." - Fred Hampton
"The common people suffer when the powerful disagree." - Phaedrus
