Crt.5 brushless overheating
Jason
Exclamation Crt.5 brushless overheating - 06.27.2009, 01:17 PM
IM BACK FROM PLAYING FOR AROUND 10 TO 15MIN WITH MY CRT.5 AND THE TEMPS WAS :
177F ESC
157F MOTOR
100F BATTERY
IN A OUTSIDE TEMPERATURE OF 18 ºC = 64.4 ºF
I DRILLED HOLE IN THE WINDSHIELD..
I PUT THERMAL GREASE BETWEEN THE MOTOR MOUNT AND THE MOTOR ...
THE CENTER DIFF WAS FILLED WITH 120K FLUID..
NOTHING HELP !
SPECS WAS :
MAMBA MAX 1/10 ESC ( BEC ACTIVATED )
NEU 1509 2.5D 2700KV
13T PINION
46T SPUR
3S LIPO TRUERC 15C 6400MAH ( I TRIED A ZIPPY 3S 5000MAH 25C TOO )
SURE IM USING BIG TIRES AND BIG BATTERY ON MY CRT IT WEIGHT AROUND 6LBS..
Differential Ratio: 3.25
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 13
Total Voltage: 11.1
Motor KV: 2700
Tire Diameter (inches): 4.72
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0082
Spur/Pinion Ratio: 3.54 : 1
Total Ratio: 11.5 : 1
Tire Circumference (inches): 14.83 inches (376.64 mm)
Total Motor Speed: 29970 RPM
Vehicle Speed: 36.59 mph (58.78 km/h)
Effective KV Value: 2700
KT constant: 0.5 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
Metallover
RC-Monster Spudgunner
Metallover's Avatar
06.27.2009, 01:30 PM
Any binding or loose solder joints? It looks like you're geared about right... What kind of driving was it? Hard offroad?
06.27.2009, 01:33 PM
3S Lipo MM = BEC and extra cap... temps will drop v quickly
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
06.27.2009, 01:57 PM
battery temp looks good, motor temp is a bit higher than expected but still safe, esc temps I'm sure are mostly due to running 3s without an external BEC, as already mentioned
Metallover
Metallover's Avatar
06.27.2009, 02:38 PM
Your truck is really heavy too. What do you have on there that makes it so heavy? Just the tires?
Snipin_Willy
Snipin_Willy's Avatar
06.27.2009, 04:06 PM
Try an external BEC, I think it'll help you out a lot.
I just tried the speed calc with my current CRT.5 setup with some 4s Lipos. 45mph! I might need a gear down some if the MM starts to cook.
Jason
06.27.2009, 04:18 PM
I will try to power my receiver with a 6v aa pack then but why I run my traxxas slash on 3s with the integrated bec without any heating issue ? and got issue with this one..
06.27.2009, 04:30 PM
Depends on the current draw from the servo. The Slash may have less weight in front, so it takes less power to turn the wheels.
Snipin_Willy
06.27.2009, 04:41 PM
And depending on your slash, you might not have as much amp draw on the motor either.
Jason
06.29.2009, 06:38 PM
do ya think this extra cap would help alot ? :
http://www.rc-monster.com/proddetail.php?prod=35vcap
and do I need to solder it on the esc board or solder it on the esc battery wire can do the same thing ? and more easy to solder ..
Jason
07.01.2009, 06:18 PM
07.01.2009, 06:20 PM
An extra cap will do little to help overheating on the BEC.
Jason
07.01.2009, 06:23 PM
only one extra cap not 2 ?
and if the motor heating up does the esc heating up too ? and vice versa if the esc heating up the motor heating up also ?
07.01.2009, 06:26 PM
I looked back at your original post and noticed you have 4.72" for the tire diameter. Are you sure that is right, it looks awfully large for a CRT.5. 1/8 scale buggies are around 4.25" IIRC.
Jason
07.01.2009, 07:09 PM
why not ?
