5th scale conversion
brushlessboy16
brushlessboy16's Avatar
5th scale conversion - 07.07.2009, 10:45 AM
http://www.riverhobby.com/1-5electric.asp
By river hobbies... never heard of them
Shown with a 580l feigao
nitrostarter
nitrostarter's Avatar
07.07.2009, 10:52 AM
Good concept there! But not digging the motor/esc/lipo selection and recommendations.
4s in a 1/5th scale? geez!
N. Rustler conversion
07.07.2009, 11:30 AM
Yeah... 1450kv on 4s? That's 21460rpm... The motor mount looks like it would also have very limited motor selection, due to size restrictions.
Foxracin
07.07.2009, 11:40 AM
The esc looks like a Speed Passion.
07.07.2009, 11:41 AM
It's a hobbywing 150a.
07.07.2009, 12:19 PM
i.e. one and the same
aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.07.2009, 12:32 PM
it would be nice if they sold the mount...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
07.07.2009, 12:33 PM
Depending on the gearing you may not want motor speed over 30k rpm, as the gas engines cannot turn much more than 15-17k rpm. So unless the gearing is way lower, high rpm motors will not work well. On the baja project, I had figured a 700kv motor on 10s lipo would work for stock speeds with a 12t pinion, 5 teeth less than the stock gas engine pinion... That was around 28k rpm...
maxair45
maxair45's Avatar
07.07.2009, 01:25 PM
HW makes speed passion, venom, and orion(not 100% sure on orion so don't quote me on that).
The mouth does look majorly restricting and is it just me or does that look like a plastic pinion? The plastic spur is nice as it'll keep the noise down a lot(I hate the sound of metal to metal meshing)
MetalMan
MetalMan's Avatar
07.07.2009, 01:34 PM
I doubt that 580L will hold up for very long, considering I killed one in a buggy that weighs at least 5lb less.
blueb8llz
07.07.2009, 01:40 PM
really? howd you do that? what buggy did you have it on?
07.07.2009, 01:51 PM
IIRC it was a XTM XLB
MetalMan
MetalMan's Avatar
07.07.2009, 01:53 PM
This thread:
http://www.rc-monster.com/forum/showthread.php?t=20807
Still need to make a thread for that buggy...
OZ-RUSTLER
OZ-RUSTLER's Avatar
07.08.2009, 05:21 AM
How do you adjust gear mesh with that motor mount?
Maciolus
07.08.2009, 06:19 AM
It looks like there is a slipper. Looks nice
> HB L2PE + MMM + Medusa 60-1600 @ 6S A123
> HB LSP + MMM + Medusa 70-1600 @ 6S2P A123
> AE B44 + MM + Medusa 50-3300 @ 4S A123
> AE J82 + SW 5700 @ 2S LiPo
> AE TC5R + MM 6900 @ 2S LiPo
