Kyosho ST problems.......
streethot
Kyosho ST problems....... - 07.22.2009, 10:25 PM
Hi there......i have a Kyosho inferno st-rr.........should be the best truggy from kyosho.....it's not......
pinion and gear are too fragile for this size of truck.....10/43 tooth.......
I ask if someone that issues with diff gears? and solutions or advices on this......I am past due changing gears......they are not cheap over here......
Now the car has front diff with bevel gear destroyed.....and i dont know what to do......have tried many setups and the only reasonable solution its a lower power level.....
mmm
neu 1515 1650kv
lipo flightmax 6s 5000mah 20/40c
gear 13/46 or 14/46
any help would be great......
George16
Supermaxx
George16's Avatar
07.22.2009, 10:58 PM
I never had any problems with mine. I just made sure I shimmed the diffs properly. Any diffs not shimmed properly can break prematurely.
My ST RR is setup with a CC 2200KV motor, Mamba monster on 5S geared at 50/15.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
streethot
07.22.2009, 11:38 PM
i dont know.......many broken front gears were after big jumps......look like on landing.....shimmed all right......but i am take it apart to check again.....
07.23.2009, 09:21 AM
If you are blowing diffs...most likely it is a shimming issue. A 1/8 diff shimmed properly will last a good long time
