WTB UE Super Shock -
08.12.2009, 01:09 AM
Like title says, looking for 4 or 8 UE Super shocks for a Emaxx.
PM me if you have any.
08.12.2009, 07:30 AM
pm sent...
08.12.2009, 09:05 AM
UE supershocks are just rebadged ofna shocks. save money and just buy front buggy shocks (same thing)
08.12.2009, 10:17 AM
I'm looking for Ofna's as well. I found a couple sites where the Ofna's are $20 a pair brand new.
The only real difference I know of is the UE shaft's are Ti-Nitride.
08.12.2009, 10:26 AM
since 1/8 shocks hae rubber dust boots TiNitride shafts are not needed. standard steel shaft can be silky smooth with little bit of polishing. the only + of supershocks were their progressive springs.
use just 4 shocks. 8 are not needed and make tuning just more complicated
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
08.12.2009, 10:32 AM
Will do. Sticking with 4.
Or needless to say, any 4 rear Truggy shocks are welcome for thought.
08.12.2009, 10:42 AM
The maxx uses a 4" shock... So just about anything that dimension (save for a large diameter shock such as a lst shock) should fit.
08.12.2009, 10:57 AM
Nitrostarter I hope you don't plan on doing alot of jumping (levees with Mark hehe) I've got 4 with 80wt and black rears, blue fronts and my truck bottoms out after a 10inch drop from my hands. Otherwise it handles like a champ with four and is lighter. For me running 4 shocks is a mistake.
Surely you you're not planning on running plastic bulks...
08.12.2009, 11:01 AM
I'm planning on all plastic unless I start breaking stuff... The diffs are my only concern, and maybe the bulks...
08.12.2009, 11:13 AM
Might as well run that plastic till it breaks, because it is so cheap. Thats what I did. I would watch the bay like a hawk, often times you can find a fairly well equiped Maxx for cheap.
08.12.2009, 11:16 AM
I'm watching as we speak!
I figure that as long as I keep it light: running 4s, LPR tires, stock plastic, 4 shocks, jangified, maybe g4 chassis, I should be ok on breakage. Less strain, less rotational mass, less overall weight.
08.12.2009, 11:50 AM
a 3s Maxx would be sweet! on like 3500-4500kv. It one of my dream trucks and it would consequently also be cheaper.
08.12.2009, 12:09 PM
I was actually looking into it. If I was going to run a 3s setup, use a 1512/1Y or 1515/1.5D. Either should easily make 35mph.
But I have a 1700kv Tekin, I'm going to run that on some lighter 4s packs and gear it for 35mph.
Should be no problem to run Mod1 with a Revo spur correct?
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
