Spur gear
bcltoys
Spur gear - 09.27.2009, 09:50 PM
Does anyone make a plastic 48 tooth spur gear for losi 8t 1.0.
Sammus
Sammus's Avatar
09.28.2009, 02:49 AM
a lot of people use the 46t kyosho spur and modify it to fit a wide range of buggies truggies. You could always try it, theyre only a few dollars.
bdebde
That's All Folks!
bdebde's Avatar
09.28.2009, 09:55 AM
Associated makes 46t, 48t, and 50t plastic spurs. Not sure they will fit Losi diff, but will have a 46t and 50t in my hand today.
bcltoys
09.29.2009, 07:19 AM
Do the associated spurs fit up.
bdebde
That's All Folks!
bdebde's Avatar
09.29.2009, 09:58 AM
Looks like the associated ones use a bit smaller diff cup, so I guess they won't work with the Losi. I may just get an entire Associated center diff. You can't get by with the 45t that Losi makes? Weird how they make larger gears in steel and only smaller in the plastic. I do like the plastic gear set up for Losi, but I think I will need larger than 45t myself (will see when I get a few pieces together).
