Homemade Charger for NiMH AA's
Homemade Charger for NiMH AA's - 03.19.2010, 09:30 PM
As some may know, I recently got a bunch of Turnigy AA LSD (low self-discharge) NiMH batteries, but wanted a portable charger for trips, or when I don't feel like dragging out all my R/C charger equipment. Most of those chargers you find at Wal-Mart/Target/etc for AA batteries are timed (at best), so can overcharge or undercharge the cells. The charger below is pretty simple, will charge two AA batteries at once, and uses a temperature cutoff. Basically, it's a constant-current charger with thermal delta-peak detection.
Here is the schematic and parts list:
  • R1: Thermistor rated 100k ohms at 77*F
  • R2: 15k ohm 1/4w resistor
  • R3: 10k ohm multi-turn trimmer pot:
  • R4: 1M ohm 1/4w resistor
  • R5: 1K ohm 1/4w resistor
  • R6: 10k ohm 1/4 resistor
  • R7: 470 ohm 1/4w resistor
  • R8: 2.4 ohm resistor made from five 1/2w 12 ohm resistors in parallel.
  • D1, D2: 1N4001 diode
  • D3: Green LED (Vf=2.1v @ If=25mA)
  • D4: 3A barrel diode
  • Q1: 2N3906 PNP transistor
  • Q2: 2N3904 NPN transistor
  • Q3: TIP120 NPN Darlington transistor
  • SW1: Normally-closed momentary switch
  • C1: 0.1uF disc capacitor
Circuit operation:
R7 and D3 (LED) together puts ~2v at the base of Q3. That makes ~0.75v at the emitter of Q3, which generates a constant battery charging current of 0.313A through R8. Diode D4 prevents the battery from backfeeding into the rest of the circuit. The LED (D3) lights up when charging and shuts off when charging is complete, so it is used for charging status as well as charging bias.
A thermistor is positioned to physically touch the batteries. As the batteries reach full charge, they start heating up. This causes the resistance of the thermistor to decrease. The voltage divider consisting of R1 (thermistor), R2, and R3 generates a higher and higher voltage at D1, until it can overcome the diode and turn on Q1, which brings the LED (D3) voltage to ~0.8v shutting off the charging transistor (Q3).
When Q1 is turned on, Q1 and Q2 transistors basically latch each other on and will keep the charger shut off until power is removed. This is to prevent the circuit from charging the batteries again once the thermistor cools. You use the switch (SW1) to cut power momentarily which resets the latch circuit. C1 just makes the circuit stable when resetting the latch.
Some assembly notes:
The voltage supply is a regulated 6v DC voltage. It is important for the voltage to be regulated for consistent temperature cutoff. If you do not want to use a regulated supply, you could regulate (using a zener diode) just the thermistor circuit (R1, R2, R3). However, if the supply voltage is much higher than 6v, there will be a lot of wasted heat on the charging transistor. So, it's best if the supply is a regulated 6v for best operation.
The charging transistor (Q3) must be on a heatsink exposed to the outside air. The hottest it will get is when discharged batteries are hooked up. As the batteries charge, their voltage will increase which means there is less voltage across Q3, and less heat. Worst case Q3 power dissipated is ~0.85w, and will go down to around 0.45w near the end of the battery charge.
The 313mA charge rate will take about 7 hours to charge a 2200mAh cell. That may seem like a long time, but ~0.3A seems to be the best charge rate for these Turnigy AA LSD cells.
To calibrate the thermal shutdown, I started with the trim pot resistance at the minimum value. Then, while charging, I monitored the cell voltage. When I saw the voltage peak and then start to decline (which signifies end of charge), I adjusted the trim pot slowly until the charge circuit shut off.
Some pics of the finished product:
I had a hard time finding the right size enclosure, so parts placement is a little odd. The switch is very big because it is the only cheap one I could find. The momentary normally-closed switches RadioShack has are absolute junk.
It's kinda hard to see, but I glued the thermistor such that it touches the cells when they are in the holder. And to improve thermal conductivity, I molded some thermal epoxy on the thermistor to conform to the cells. Once it cured, it worked pretty well.
The inside. Yeah, it's pretty packed in there.
On the far right is the input power jack. I was going to put the whole power supply inside (using a bigger box), but this enables me to use 12v from a car cigarette outlet, or a 120v "wall-wart" power supply. I put a 1000uF capacitor for a little better filtering in case the supply is a bit "noisy".
On the top right is a modified cheap Chinese $5 R/C BEC. I removed the jumper lead and feedback resistor, and installed a 2.2k ohm resistor to provide a consistent 6.14v. The BEC allows me to use pretty much any DC input from ~8vDC all the way up to ~35v. Pretty flexible. And, typical of a switching BEC, the higher the input voltage is, the lower the required current. The following is a list of power supply requirements at various voltages: 9v @ 300mA, 12v @ 220mA, 18v @ 150mA, 24v @ 115mA, 30v @ 90mA. Any of these will function perfectly.
The messy pack of resistors on the far left is the 5 paralleled 12 ohm resistors to make the 2.4 ohm current-programming value I needed. There simply wasn't enough room on that tiny circuit board for them. The rest of the components are on the board though, but it was a tight fit. The blue "box" with the round brass button on the bottom of the board is the trimmer pot. I use it to initially tweak the circuit until the charge stops at the right temperature.
To be clear: I do not plan to market this thing. I just figured people might want a small, cheap, and simple charger.
