Made my own Baja 5T boot protectors, mudguards & carb filter *w/pics*
Freezebyte
Made my own Baja 5T boot protectors, mudguards & carb filter *w/pics* - 05.02.2010, 02:12 PM
Ok, as much as I have enjoyed my new 5T this last month, its become apparent that these things can cost some serious money to help make them more "bulletproof" outa the box in stock form. Lately, the first thing to come to my attention was the amount of punishment the dog bone boots take and how quickly they wear out, rip and need to be replaced. Don't think I need to tell you how annoying this is after just a few runs and cleaning up grease throw all over the chassis after they fall apart in mid ride. I've already replaced two stock HPI sets and it was getting really old and even aftermarket ones will only last so long.
Another thing that came to my attention was the possible damage to the carb diaphragm as a result of intaking dust/dirt while in usage. Their is a small intake hole near the fuel bulb that over time according to other peeps, will suck enough dust to require repairing the carb. Well that just plain sucks....
I was also tired of looking at these huge gapping holes in my front fender wheels where basically anything could get in or thrown in by the front tires. Not only did it look terrible, but it allow every single rock and dust particle easy access.
Of course, some smart, business people have discovered these faults and have made products to help reduce or prevent all this premature wear and tear on our Bajas. For a price. Team Chase's diagram filter and boot guards are a very nice in their own right as is ATX' products for front and rear mudguards for the 5T.
However, after seeing the total in my cart at DDM for all this stuff, I was somewhat sickened, thinking to myself "I should haven't to shell out this kinda money just for basic protection" True, good stuff costs but I'm on a budget like the rest of you and even though I really enjoy my Baja, some hobby fun stuff just arn't justifiable in comparison to pay off life's other obligations.
After seeing other peeps make their their own mudguard, and boot protectors, I saw no reason not to make my own, come out money ahead and hell, even make a better product custom made for me needs! With that, I set in motion this weekend to collect the few materials I would need. Everything I got locally at my local ACE Hardware and only cost me less then $14 and a couple of hours of work. Hmmmm $125 vs $14 with some work? I rest my case....
I had some tin snips and a drill already with me, so I purchased some appropriate sized wood screws, nut and bolts and some kinda stair/wall protection panel that was made out of a thick rubber that was nice and stiff, but still flexible. I also had a spare filter element and plenty of zip ties, so no cost their! With that, I went to work this weekend.
Measure three times, cut once!!!! *learned the hard way*
I did a rough outline of what I wanted with a pen and then cut out each boot protector plate for each side
After cutting out the panel, I had to trim a little at a time to make sure the cover would not bind up the suspension arm. this took awhile for the left side with the spur gear assembly in the way. I also had to test the suspension to make sure the boot guards would not prevent the suspension from articulating all the way. Again, trim, check. Repeat as necassary.
After being satisfied with the trimming, I then processed to SLOWLY drill four small holes into the cover and lower arm. Again, Measure, check, measure check, repeat as necassary. Afterwards I used 4 screws to attach the boot guard cover to prevent any flexing during heavy usage.
That should take care of my boot covers ripping now!
With the rears done, I had plenty of material left over for front mudguards. Again, it was pretty much measure, checking the fitment and trimming as necessary *with a few mistakes* I wanted to be sure I covered as much of the wheel wells as I could without causing rubbing on the body and taking off the paint.
After making sure of basic fit, I drilled two holes on each side of the undercarriage guard to attach the mudguards. This way, I can remove the carriage and mud guards at the same time.
I attached the mudguards using small nuts and bolts. To keep the nuts from loosening off during hard bashing, I little blue loctite should take care of that.
Those guards arn't going anywhere
