What size is this?
Braden
What size is this? - 05.13.2010, 01:56 PM
Is this a 550 size motor?
http://www.amainhobbies.com/product_...less-Motor-45T
Looking for something to go into a slash 4x4.
This would be a good replacement for the novak 4.5 550 motor no?
http://www.teamepiconline.com/shop/i...?item=TRI10211
Would the first one be good enough on 2s with a MM pro?
05.13.2010, 02:15 PM
No.. its designed for 2wd
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
05.13.2010, 02:35 PM
+1- 1/10 scale 540 size
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.13.2010, 02:49 PM
That second motor would most likely require more voltage and not work well on 2s.
www.cubicle101.com
Braden
What motor would work good on 2s in a slash 4x4 with a MMM or MM pro esc?
brushlessboy16
brushlessboy16's Avatar
05.13.2010, 05:58 PM
Neu 1409 1y
3600kv, tons of torque and very efficient
Braden
05.13.2010, 06:00 PM
Dang thats pricey at $140...
I guess as long as its worth it?
brushlessboy16
05.13.2010, 06:04 PM
Well before you say its price, know that neu motors are close to, or THE top of the scale when it comes to motors
Quality materieals, designs and manufacturing makes them tops. Their motors are some of the most efficient (less power to heat, more to wheels), and torqui-est (made a word?) you can buy. Castle creations based their 1/8th scale brushless motors off the original neu design..
THey are one of the best money can buy and you will not be dissapointed
Braden
05.13.2010, 06:06 PM
I know that...
I might of found a novak hv 4.5 for 35 bux... Then I might trade off my MMM for a MM pro...
If that fails I guess im getting the neu.
Thanks for the help.
Braden
05.13.2010, 06:16 PM
Turns out to be the novak velociti.... Not the hv...
brushlessboy16
05.13.2010, 07:19 PM
doh!
Braden
05.13.2010, 07:20 PM
Im just going to run a CC-neu 2650 motor... Found a new one for a good price.
Gear it higher and it is suppose to be fast enough for the track.
brushlessboy16
05.13.2010, 07:31 PM
Might as well run 4s :)
Braden
05.13.2010, 07:32 PM
I have a couple 4s that I use in my revo conversion... 2s are cheaper and charge faster on my little charger. Fast enough for the track.
Im going to be geared 18/54 or 20/54... Depends what I like.
simplechamp
simplechamp's Avatar
05.13.2010, 07:51 PM
Maybe try one of the new Ballistic 550 motors with an MMP.
