question about stripped threads
rschoi_75
Certified Spaceball
rschoi_75's Avatar
question about stripped threads - 06.20.2010, 12:40 PM
I didn't know exactly what forum to ask this, so I guess I'll ask here.
What do you guys do when you've stripped the threading on an aluminum hole? I know I can jb weld the hole, and then re-tap and re-thread.... but is there an alternative that does not require JB?
rcm xt8
rcm xb8
rcm crt.5
rawfuls
roofles.
rawfuls's Avatar
06.20.2010, 01:02 PM
Going a size bigger?
That's what I do on the plastic arms, given, it's plastic so it's easier...
Go to M4 if it's an M3, if you can?
rchippie
rchippie's Avatar
06.20.2010, 01:32 PM
Use a helicoil.
REAL MEN RUN BRUSHLESS
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
06.20.2010, 07:32 PM
What part is this? Can you just drill through and use a locknut on the other end? If it's a bulkhead or a diff mount etc. there is probably enough material to go a size bigger as was suggested.
Duster_360
06.20.2010, 08:08 PM
I've had success using helicoils. Helicoil repair is stronger than the orig threaded hole so there's never any question/doubts about it again.
rschoi_75
Certified Spaceball
rschoi_75's Avatar
06.20.2010, 10:02 PM
No I can't use a lock nut on it... its a part that the screw can not go fully through. Thanks for the helicoil suggestion. It seems to be exactly what I need.
rcm xt8
rcm xb8
rcm crt.5
