LX-1E buggy to truggy
jamesban
LX-1E buggy to truggy - 07.19.2010, 12:45 PM
I wanted to put some truggy wheels on my LX-1E if possible. Im not going to lengthen the arms or anything just throw some stablemaxx wheels on it. Would this be possible with gearing down. Would I have to go with a larger spur or can I go low enough with the pinion to run it safely?
scarletboa
scarletboa's Avatar
07.19.2010, 09:02 PM
You would also need a longer chassis for it. If you do get a longer chassis, please, let if you if you are willing to sell the stock chassis. I bent mine pretty bad and I could use a cheap used one.
jamesban
07.20.2010, 02:48 PM
I don't want to lengthen the chassis. I just want to know if gearing it down would work or do I have to change the diffs also?
rootar
rootar's Avatar
07.20.2010, 05:33 PM
if it does not have 43/10 ratio diffs then it might be hard to gear it low enough.
