Lowest "Safe" voltage for 2s?
Muggydude
Lowest "Safe" voltage for 2s? - 09.22.2010, 05:56 PM
Just wondering, what's the lowest "safe" voltage I should see on my 2s packs after a full run? (The voltage the charger sees when first plugged in) Thanks
R.I.P. Muggy, Rustler, VXL Slash
EFlite Blade MSR Heli (Slightly modded)
1/16 BL E-revo
8-t 2.0, OS Vspec with Speed conrod
Carbon Fiber Revo 3.3 Coversion Madness!
crazyjr
crazyjr's Avatar
09.22.2010, 06:02 PM
Most chargers will not even charge if the voltage is under 3.0v per cell, its in the programming
Muggydude
09.22.2010, 06:20 PM
Ok, but what's a safe voltage for the batteries?
1/16 BL E-revo
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
09.22.2010, 06:52 PM
Oh no! We're stuck in an endless loop!
Muggydude
09.22.2010, 07:30 PM
So as long as it doesn't read 6.0V I'm fine?
1/16 BL E-revo
crazyjr
crazyjr's Avatar
09.22.2010, 08:00 PM
Most here run 3.1V voltage on their cut-off and the batteries come back to 3.3 to 3.4v per cell as they cool down. I personally run my cut-off to 3.0 and charge when cool and have never had troubles with any good pack. My maxamps puffed within a year but my hyperions and flightpowers have lived over three years and still going strong
What's_nitro?
09.22.2010, 08:15 PM
Even if the cells are below 3V at rest, all is not necessarily lost. You can try charging them very slowly (like 1/10C, 0.5A for a 5K pack) and see if they retain any capacity. Bear in mind you should be watching the charge cycle closely in case the pack decides to puff.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.22.2010, 08:29 PM
High qaulity packs, Hyperion, ThunderPower etc (excludeing MA) will come back just fine if cut off is at 3.0 per cell but still should be set at 3.1-3.2
The cheaper packs IE HobbyCity, Blue Lipos, Batman etc I would use a consevative cut off of 3.4-3.5 to be safe. These packs seem to really struggle getting back to where they need to be when drawn down to low.
Semi Pro
Semi Pro's Avatar
09.22.2010, 09:08 PM
i cut at 3.2v thats what hyperion recomends
Muggydude
09.22.2010, 09:23 PM
Ok, pack was at 6.5v, so it should be fine? For some reason I had though below 7.0V was bad, no idea why...
1/16 BL E-revo
09.26.2010, 02:34 AM
yes, it's fine. I also have no idea why you thought that.
Muggydude
09.26.2010, 04:41 PM
I think I need more sleep...
1/16 BL E-revo
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.26.2010, 04:54 PM
Yeah, you look like shiz ?
Muggydude
09.26.2010, 09:16 PM
Do you have a camera in my home? Haha
1/16 BL E-revo
