Project: Madness
Big House
Big House's Avatar
Project: Madness - 10.02.2010, 09:57 PM
Picked up a pretty good Mayhem ST roller for a guy at a local hobby store. Equipped with servos and all. Both work but the JR steering servo hums way to much. I will be replacing that one. I don't have room for the manual brake so the motor will have to do. Speaking of the motor, thanks to the Castle Clearance sale, picked up a 1520 and I think it will do well in pushing the new beast.
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
nitrostarter
nitrostarter's Avatar
10.03.2010, 01:38 AM
Glad you found a truck.
I know I offered my Emaxx roller for sale but since throwing in the CC1518, I've been having too much fun beating it up!
N. Rustler conversion
Big House
Big House's Avatar
10.03.2010, 01:22 PM
I understand how that is.
CF Losi LST2
Project: Madness Pt. 1
Big House
Big House's Avatar
Project: Madness Pt. 1 - 10.03.2010, 04:53 PM
Here are a few pics of the tear down and clean up of the new project: Madness.
Name:	Side shot dirty.jpg
ID:	9391   Click image for larger version
Name:	Mayhem dirty.jpg
ID:	9392   Click image for larger version
Name:	Top shot dirty.jpg
Name:	Dirty on the stand.jpg
CF Losi LST2
Project: Madness Pt 2.
Big House
Big House's Avatar
Project: Madness Pt 2. - 10.03.2010, 05:07 PM
Here are the cleaned up shots:
Name:	Clean front shot.jpg
ID:	9395   Click image for larger version
Name:	Clean layout.jpg
ID:	9396   Click image for larger version
Name:	Clean top shot.jpg
CF Losi LST2
Project Madness Pt. 3
Big House
Big House's Avatar
Project Madness Pt. 3 - 10.03.2010, 05:11 PM
Here is the battery and motor layout.
Name:	Front shot motor and battery.jpg
ID:	9398   Click image for larger version
Name:	Motor and batt layout 2.jpg
CF Losi LST2
10.03.2010, 08:52 PM
That will be a monster w/the 1520 in it
nitrostarter
10.03.2010, 09:28 PM
Is that LST ft/rr diffs?
10.03.2010, 09:46 PM
The sportwerks mayhem st should use the same diffs as the lst, with muggy ratio gears. Stout for a truggy, but as close to muggy as you will get for drivetrain strength.
Motor mounted
Big House
Big House's Avatar
Motor mounted - 11.11.2010, 09:49 PM
I order a Tekno RC motor mount for the Madness project and discovered the mount did not line up at all with the stock motor mount positions. I took a piece of carbon fiber and fabbed a motor mount plate and got it in. The Castle 1520 is a beast, plain and simple. All I need now is a MMM, battery tray and better steering servo.
CF Losi LST2
bigboi146
Multi Tasking
bigboi146's Avatar
11.15.2010, 11:29 PM
Are you sure you want the layout with the huge motor and battery in the rear? You should try to balance it out somehow.
Big House
Big House's Avatar
11.16.2010, 08:31 PM
Due to the limited space, I don't have many configuration options. If necessary, I will have to add a little weight up front.
CF Losi LST2
Madness update
Big House
Big House's Avatar
Madness update - 11.25.2010, 02:38 PM
I got he battery tray installed. I ordered one of Mike's battery trays and heat implanted two bolts into the tray so to attach to the chassis. The technique worked well as the I can attach the tray without the screws poking into the side of the battery. The tray also gave me a little room to move the battery forward in the chassis to distribute a little weight though not much.
The motor is mounted, the battery tray is installed, the only thing left is to get the MMM and charge the batteries and we will be in business. Maiden brushless run will be Saturday.
Name:	Madness with battery.jpg
ID:	9506   Click image for larger version
Name:	Layout with Batt tray.jpg
CF Losi LST2
The Madness lives...
Big House
Big House's Avatar
The Madness lives... - 11.26.2010, 10:29 PM
First test run was a complete success. GEared at 15/51 I think, it is peppie on 4s. I am going to keep it there until I get it dialed in. Can't wait to open it up.
CF Losi LST2
