Closed Thread
FS Futaba 3PM-X 3-Channel 2.4GHz Transmitter/Receiver
FS Futaba 3PM-X 3-Channel 2.4GHz Transmitter/Receiver - 01.09.2011, 08:48 PM
See link for details... Basically BNIB...
http://www3.towerhobbies.com/cgi-bin...&I=LXXRL8&P=ML
This is the Futaba 3-Channel 3PMX Computer Radio with the
2.4GHz FASST System.
Transmitter and R603FF receiver only, servos not included.
The 3PMX is also capable of using the R603FS receiver
to give modelers special Dual Antenna Diversity (DAD).
**The 3PMX adds three new features; Four Wheel Steering Mixing,**
**Digital Trim Step and Adjuster for Crawlers, Monster Trucks**
**and any four wheel drive vehicle. These features allow drivers**
**to apply mixing between steering, throttle and channel 3.**
FEATURES: FASST (Futaba Advanced Spread Spectrum Technology) sends twice as
much information to the receiver at eight times the resolution of
standard systems for unsurpassed control and smooth servo travel
2.4GHz circuitry is wired directly into transmitter eliminating
separate plug-in modules
"Auto Detect" instantly determines whether HRS or PPM mode is active
in the receiver (R603FS only)
Special ID code prevents signal interruption by rejecting unwanted
signals
Brake mixing for large cars
Anti-skid braking system (ABS)
Throttle Acceleration (ACC) minimizes time lag before clutch and
brakes are connected in gasoline engine cars
Steering speed adjusts steering servo operating speed
Racing timer
Function select lever function
In addition to great performance in R/C car and truck applications,
this system is also ideally suited to the rigors of boat racing
10 Model Memory
One year limited warranty through manufacturer
INCLUDES: 2.4GHz FASST Futaba 3-Channel 3PMX transmitter
2.4GHz FASST Futaba R603FF 3-Channel Receiver (FUTL7631)
ON/OFF switch harness
Instruction manual
REQUIRES: AA Batteries: Eight for transmitter
Servos of modeler's choice
01.15.2011, 01:36 PM
Closed Thread
