I have decided, after years of pondering, to commit to finding a liquid cooling solution to my RC vehicles.
I looked seriously into doing this years ago when we used to mod the original Mamba Max's for 6S use.
Back then there were no readily available micro sized fluid pumps that would fit the bill.
It ended up going no where, mostly because of the sheer cost of the endeavor.
Today is a different story.
My financial situation has improved, the pumps seem available, and there is more reason now than ever to complete a functioning system.
My primary goals are a solution that would allow me to put an ESC in an enclosed waterproof container and use it in extremely harsh environments without damage or heat issues.
I want water cooling for the ESC, motor, servo's and be able to use the same system from 1/10 scale to 1/5 scale.
I envision this system being used on SC trucks that are ROAR limited to small motors that could benefit from high levels of cooling.
I have a few unique ideas that I have not seen done yet that I think could make this a very clean and functional proposition.
First would be using the aluminum chassis as a radiator, I mean it is a large hunk of aluminum with air flow across it when the RC is in motion.
For higher capacity cooling needs I could use a traditional fan and radiator setup.
Second would be using purpose built "negatives" of the ESC's heat sink to conduct the temps into the cooling system.
For example removing the fan assembly from a MMM and inserting a cooling sink (chunk of aluminum with liquid cooling passages machined in and sealed for coolant flow) that fits onto the MMM's sink with a fine layer of non conductive thermal paste.
I don't want to negatively affect the warranty, and have a system that is easy to remove for swapping the system to a new vehicle or ESC.
The chassis could be turned into a radiator by attaching a liquid sink that is basically a thin aluminum block with cooling channels machined into it and sealed for coolant flow.
It could be attached to the chassis with either thin thermal tape, thermal adhesive, or bolted down with a thin layer of thermal grease.
For a smooth motor a standard boat cooling coil could be implemented. And for finned motors I could develop a special coil that matches the fins better.
I'm also curios if it's possible to create sealed end bells for brushless motors that could pass the (non conductive) coolant directly through the motor to cool the inside vs the outside.
Servo cooling could be a scaled down version of the chassis sink.
I expect the project to go slowly and take the better part of 3 months to complete.
I have Autocad 2011 software (inventor, mechanical, showcase, vault, ect).
After a month or so I should have around $400 to start piecing it together... though the budget is certainly not limited to $400.
When it's all said and done I would like to be able to put together the entire system for under $200
I really want to pull this off successfully and I'm going to make it happen.
Any comments, ideas, criticisms, or wisdom welcome
