help with finding a BEC
Hyper-5
The-Hyper One
Hyper-5's Avatar
help with finding a BEC - 04.07.2011, 05:34 AM
Hey, dont really know much about this but, lm looking for a BEC but don't know how many volts or amps l need? my set up is 150A ESC, 11.1v lipo, how many amps/volts do l need?. Can anyone help?
04.07.2011, 08:06 AM
Just get a castle bec.
pinkpanda3310
pinkpanda3310's Avatar
04.07.2011, 08:11 AM
Like this one?
Hyper-5
The-Hyper One
Hyper-5's Avatar
04.07.2011, 08:33 AM
ye, l just orded the Castle CC-BEC-PRO V2 Battery Eliminator Circuit 20-Amp
OZ-RUSTLER
OZ-RUSTLER's Avatar
04.07.2011, 10:31 AM
You do realize that the Castle Bec Pro 20a is about the size of a Sidewinder ESC?
The Castle Bec 10a is more than enough for your application, and it's tiny.
brainanator
brainanator's Avatar
04.07.2011, 10:57 AM
BEC should be speced out based on your input voltage and what servos you are running, you're ESC doesn't matter, nor does your motor.
bruce750i
bruce750i's Avatar
04.07.2011, 05:09 PM
Your new (switching)ccbec pro(3-12v adj@20amps) will be powering your rx, servo and fan(s), instead of your esc's (linear) internal bec(6v@3-5amps). IMO Most your gains will be heat reduction from changing the type of bec. switching vs linear. You could run your servo faster by adjusting the bec voltage up to 6.5 volts max.
Hyper-5
The-Hyper One
Hyper-5's Avatar
04.07.2011, 06:19 PM
orite, would this BEC be any good, 5A UBEC High Voltage BEC?
simplechamp
simplechamp's Avatar
04.08.2011, 01:38 PM
The Castle BEC Pro will be fine if you already ordered it, it's just a little overkill for a 1/8 vehicle. The regular 10A adjustable Castle BEC is plenty for what you need. The small one in blue heatshrink.
