What would this do ? (besides voiding the warranty)
bdebde
That's All Folks!
bdebde's Avatar
What would this do ? (besides voiding the warranty) - 07.02.2011, 04:46 PM
I have been running an old MM that I have soldered a receiver plug to the (+) and (-) coming from the battery (at the circuit board), so I can run my receiver at full lipo voltage. The old MM's heatsink popped off last time at the track and I would like to replace it with a MMP.
I plan to remove the red wire from the MMP receiver plug that goes to the bec and solder directly to the (+) battery connection on the circuit board, thus bypassing the bec. This will also reduce the wiring, as I now have 2 plugs from the MM to the receiver.
The questions are:
I know the warranty will be void, but I would like to know if this would work the same? Will it matter that the (-) is still at the bec connection? (should be common). And for programming, I should be able to hook to computer as long as I have red wire in plug unhooked and battery plugged in? Same for programming with field link as well, but adding a power source for field link? Or will field link handle the voltage of full lipo if leaving red wire attached?
Oh, and you could call this the MMP 2 cell addition (lol).
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
07.02.2011, 05:43 PM
Why not just hook up to computer with Castle Link and turn up the bec voltage. On the MMP the bec is adjustable.
bdebde
That's All Folks!
bdebde's Avatar
07.02.2011, 06:26 PM
Yeah but then I still need a capacitor on the receiver (high current draw servo) which doesn't always work... and you can't get 7.4+ volts either. Also there is voltage drop as well when the pack gets low (you won't get 7v out when your pack is at 7v). Some have to resort to a bec with the MMP because it won't power a high draw servo and transponder etc.
