Best way to remove chrome from plastic
K1RC
Best way to remove chrome from plastic - 02.04.2012, 08:52 AM
Hi I have a bumper here that has seen better days and the chrome paint is flaking badly. I just wondered what the best way is to remove it and are there any ways to re-paint it? Thanks in advance
ID:	10251   Click image for larger version
cmac
cmac's Avatar
02.04.2012, 10:00 AM
Yes I would like to know if this can be done without damaging the plastic too. I have a set of wheels that would look really cool in flat or satin black instead of chrome. I would think any chemicals would damage the plastic and sandblasting might scratch the plastic. I was thinking of just doing a light sanding and then spraying primer and then painting the wheel. I would guess that it would be the same for your bumper.
gumleguf
gumleguf's Avatar
02.04.2012, 12:29 PM
Haven't tried it myself but maybe Acetone?:
http://www.youtube.com/watch?v=_X7aK9XgkuI
cmac
cmac's Avatar
02.04.2012, 01:09 PM
you don't think it will ruin the plastic?
gumleguf
gumleguf's Avatar
02.04.2012, 01:28 PM
Not making any promises but I know it's a commonly used method for removing tires from wheels.
cmac
cmac's Avatar
02.04.2012, 01:56 PM
Yes you are right. I think I have seen that somewhere, and the wheels were fine. I just wish I had an old wheel or something I could test it on.
josh9mille
josh9mille's Avatar
02.04.2012, 02:01 PM
try some Brakleen (brake clean)
dirtdiver
02.04.2012, 02:33 PM
This might sound crazy,back in the day when i was building model cars i use to vinager
to remove the crome on bumpers and some crome wheels.Just let it soak for a couple
of hours or let it soak overnight.The crome will come right off with out damaging the plastic.
JAILBIRD
02.04.2012, 03:37 PM
I stripped the chrome off a set of Proline wheels. I used Easy-Off oven cleaner to dissolve the chrome. Spray it on and leave it until you see the chrome dissolve. Then I used a scrub brush to get into the cracks. Under the chrome is a yellowish coating. Im guessing the coating is used to make the plastic conductive so it can be plated. I can't remember if I used the oven cleaner or simple green to get the yellow coating off. I tried one and it didn't do anything, but the other stripped it right off. after that I tried to dye the wheels bright yellow and they looked like crap, so I dyed them black. They came out looking pretty good. The dye job isn't as good as a fresh set of white wheels. I've also never had any problems with the wheels as far as durability etc.
K1RC
02.04.2012, 05:03 PM
Originally Posted by JAILBIRD View Post
I dyed them black.
What did you use to dye them?
JAILBIRD
02.04.2012, 05:19 PM
Rit dye, liquid or powder.
K1RC
02.04.2012, 05:55 PM
Yeah most people seem to use that and get pretty good results
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.04.2012, 10:31 PM
I tried dying chrome Proline rims once, the chrome came off and they were semi-gloss black and they looked great.
MiRatlhed
RCMTC-MI
MiRatlhed's Avatar
02.05.2012, 03:23 PM
I soak Tamiya TXT rims in Purple Power cleaner overnight and it makes the chrome vanish and does not hurt the Tamiya plastic. You can soak them for 2 weeks without it hurting them. But it works great overnight for me and the stuff is cheap. Get it at Advanced Auto stores.
