Ofna GTP2E build question
wellby
wellby's Avatar
Ofna GTP2E build question - 03.22.2012, 10:34 PM
In a few days I'm going to building a Ofna GTP2E as a basher/speed run car. I will be using a mamba monster ESC with CC cap pack and BEC on from 3s to 6s. The motors that I have at the moment are a CC1512 2650kv CC1520 CC1717 and a Neu 1521 1y. I leaning towards trying the 1717 and a large pinion gear but the 1512 would be easier to gear. What to you guys think?
cmac
cmac's Avatar
03.23.2012, 01:03 AM
I would go with the 1717.
wellby
wellby's Avatar
03.23.2012, 10:38 AM
That's what I was thinking but the 1520 and 1521 have a higher max RPM and my make gearing easier but a 1717 is proven to do the job and the should run about the same RPM's as the others on 6s
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.23.2012, 02:18 PM
The 2650 gets my vote - fun on 3s and fast oas hell on 6s.
03.23.2012, 09:07 PM
In my mrx3 I run a 1512 on 6s and it is scary fast
hemiblas
hemiblas's Avatar
03.26.2012, 11:47 AM
I just put one together with the Castle 2200, MMM 6S lipo and the stock pinion. Its crazy fast. I think the 1717 might be a bit much, considering you want to keep it as agile and light as possible, which is probably why Mike is recommending the 2650.
wellby
wellby's Avatar
03.26.2012, 11:58 AM
Thanks I'm going to try the 1512 motor 1st but I will try all of them since I have them ,it will make for a interesting experiment . Going to put in a order for some of Mikes largest pinions do I can try the lower KV motors.
new pics
wellby
wellby's Avatar
Smile new pics - 03.29.2012, 11:02 PM
Got the car built up today lots of fun but need better tires and possibly try to fit a center diff in. Using to 2650 kv motor with a 22 tooth pinion on 3s or 6s.
On 6s its a animal on 3s its lots of fun
ID:	10307   Click image for larger version
nastety92
03.30.2012, 08:08 AM
Car looks great. Did you use 3m carbon fiber sheet on the body?
Nick
Tamiya TRF801Xt-e
wellby
wellby's Avatar
03.30.2012, 09:02 AM
I don't know what the carbon overlay is got the car off a member from another rc forum with the body painted and trimmed when I got it but it looks like the carbon wrap it's kind of thick and doesn't scratch very easily
03.30.2012, 10:53 AM
I did a mbx-5 on road conversion and in it I run a 2200cc motor on 5s and it is a lot of fun. Speeds around 50-55. I went with the 2200 due the longer rotor hoping that it would take more abuse and so far it has.
I have most of the electronics out for this pic for servicing
here is a lousy pic with the body
snellemin
2 KiloWatt RACER
snellemin's Avatar
03.30.2012, 11:18 AM
I'm digging the color combo on the body Magman.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
wellby
wellby's Avatar
03.30.2012, 11:52 AM
The 2650kv motor runs. nice and cool on 3s a little
warm on 6s I think 4s would be perfect with this. combo when not trying to go Mach 1 :)
Still going to try the bigger motors but the thing on 3s only weighs a little over 8 pounds so lots of torque will cause problems ,fun problems but I'm still going to try
myndseye
myndseye's Avatar
05.27.2012, 06:34 PM
where did you find those 12 spoke GRP wheels?
