Looking for set-up suggestions for running high speeds.
JAILBIRD
Looking for set-up suggestions for running high speeds. - 04.19.2012, 05:51 PM
I just finished a build to try my hand at some speed runs and I need some vehicle set-up suggestions. I'm using a lowered Stampede 4x4 as a base with a CC MMM and 2650 motor. The current gearing is 23/50. The set-up as it sits now is, Revo shocks w/ Slayer springs, Rustler body, and Jaco Foam tires, thats about it.
I'm looking for suggestions on how soft or stiff I want the suspention, throttle curves, etc. Thanks for any help!
-JB
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.19.2012, 06:14 PM
Make it heavy, low and stiff. Longer will also help straight-line stability. Punch control(up to 100%) will make launches easier to keep in check. High timing will also contribute to speed.
phildogg
phildogg's Avatar
04.19.2012, 07:23 PM
Run no lipo cut-off also. just make a couple passes then recharge.
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
hashemio
hashemio's Avatar
04.19.2012, 10:49 PM
Sway bars would do a world of difference as well. It would reduce the body roll and make high speed turning a lot easier.
