1/8 Tire question for those who race
1/8 Tire question for those who race - 07.14.2012, 08:57 PM
Ok...finally finished my ten T conversion and may want to try my hand at racing again this fall after a 20+yr absence. ( should be interesting ) Now, my truck has the 17mm adapters on it so what I need is info on tires/inserts for different surfaces from grass to packed clay to loam. Any help would be greatly appreciated.
nitrostarter
nitrostarter's Avatar
07.14.2012, 09:14 PM
Are you going to be running the Ten T in the 1/8 buggy class? Or is there a 1/10 Truggy class?
N. Rustler conversion
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.14.2012, 10:33 PM
+1 ^^
Theres no organized class for thr 1/10scale truggy unless your running with buddies for funzies ?
I would check with the guys whom run on the track what works for them since they are fimilar to it's ever changing surfaces.
07.15.2012, 08:08 AM
Well...I was going to try the 1/8 class for kicks seeing as I don't own a true 1/8 buggy anymore. At the track where I am thinking of...they do have a 1/10 unlimited class. Meaning they group SCT and trucks like ten t together.
So, I know that bowties are a good basic starting point for many surfaces...but what about inserts. The compounds have come along way as have the inserts. I know that the track is a clay base that drys out in the summer as gets like concrete.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.15.2012, 08:13 AM
Caliber in M3 with med foams IMO, should be a good all around tire.
You could just put a 1/8scale buggy body on your truck and viola', buggy.
07.15.2012, 12:45 PM
Going to do just that..just have to order one. Will look into those tires...thanks
nastety92
07.15.2012, 02:08 PM
Where are you going to race, RC Excitement?
Tamiya TRF801Xt-e
07.15.2012, 05:10 PM
possibly....there is a smaller track closer to me...can't remember name off the top of my head. The bigger track is 2 hrs away which is a stretch, but doable. Due to the distance I will need to travel, it is going to take a commitment to do this so still not 100% sure I can commit the time needed, but still would like to if possible
nitrostarter
07.15.2012, 09:42 PM
AKA GridIrons and City Blocks is the local choice out here on red clay. Most run the foams that come with the tires.
