Does anybody know if the 2 speed brushless gear adapter uses Mod 1 gears?
alexart77
Does anybody know if the 2 speed brushless gear adapter uses Mod 1 gears? - 04.22.2014, 06:55 PM
Does anybody know if the 2 speed brushless gear adapter uses Mod 1 gears or what pitch they are? I'm trying to find out whether it will be compatible with my ofna DM1 spec 2 speed brushless conversion from tekno-RC? I tried e-mailing monster-Mike but got no response. if anybody has any information on this subject. that would be very helpful!
Thanks
bdebde
That's All Folks!
bdebde's Avatar
04.22.2014, 09:25 PM
The threaded gears for the threaded gear adapter and lst2 are mod1
04.23.2014, 12:22 PM
Correct, this can use RCm mod one thread on pinions or the Losi thread on pinions for the LST series. Do not bother with the Losi pinions unless you use the TiN coated gears. I would suggest using the RCM pinions over all others as they are hardened.
And the DM1 does use mod1 pitch gears so you will be good to go.
alexart77
05.01.2014, 12:29 AM
Thanks for the info guys and sorry for the late reply!
