running a little hot
damon
running a little hot - 06.23.2006, 06:00 PM
It has been a while since I've had a question. I got the truck all set up and then the rain season started, now it is over!
Set Up - mostly stock E-Maxx. 12020/8xl, 18T, 51T ofna on strobe, Mikes heat sink on motor, MIP CVD, stock tires, rest is stock, 12 cell IB3800
Initial set up was on a 20T pinion. Temps on controler upper 140's, on motor upper 130. I went to an 18 tooth and same temps.
Do I need to go with a 16T? I put some pic of the truck in here. I could shave about 2.5 iches on one side and about 1 onch off the other from the lines going to the batteries, 2 inches off the jumper and about 2 inches going to the motor. If I could avoid putting a fan on the controller, it would be nice.
What do you all think? Would trimming all the lines make a difference?
ID:	1327   Click image for larger version
ID:	1328   Click image for larger version
MetalMan
MetalMan's Avatar
06.23.2006, 06:05 PM
Your temps seem fine.
capitol
06.23.2006, 07:44 PM
Your temps are about where mine are and I run 16t/51 ofna with big joes
btw clean set up and I really like your shocks :004:
Superbasher
Superbasher's Avatar
06.27.2006, 01:54 PM
damon, just wondering what sort of sppeds are you getting on 12 cells with that BL setup?
thanks!
SB
  Send a message via MSN to Superbasher
