90T or Long Travel Rockers?
jhautz
jhautz's Avatar
90T or Long Travel Rockers? - 06.22.2006, 04:47 PM
Are the long travel rockers better for bashing than the 90T that are out of the box? I have mys suspension set up cus I tend to ruin in some rougher areas that I want the extra clearance. Will the LT rockers raise it up from the 90T ride hieght. Or will the ride hieght stay the same and it will just alow the suspension to have a longer travel.
The way I'm set up right now, I reach the end of travel just as the chassis touches the ground when I check it on a flat surface like the workbench. Should I be using the LT to allow it to bottom on the chassis and prevent suspension damge? I have already bent one of the pushrods the last time I ran. Do I need diferent pushrods if I go to the LT rockers? Different springs? I am assuming are the springs that came with the new vehicle.
I could mess with it and figure it all out, but I figured someone here will know and be able to give me a quick answer.
to make it...
or break it...
Silent...But Deadly
