daaang
Shadow350Z
Shadow350Z's Avatar
daaang - 10.01.2006, 03:37 AM
woow i havnt been on here since forEVER!!!!
hows everybody
so yeah
will the 17mm wheel convertion from HPI fit the maxx?
cuz i wanna get this
4731 2pcs MOUNTED PHALTLINE TIRE 140x70mm on TREMOR WHEEL CHROME
from HPI
for my Maxx
btw I havnt touched my maxx for over a year =[
just no time
i gotta disassemble everything and clean and reassemble b4 running to check stuff =D
thanks in advance
  Send a message via AIM to Shadow350Z
Serum
Serum's Avatar
10.01.2006, 03:48 AM
Welcome again..
Nothing fancy happened, only thing is that Leroy (coolhand) is cheating on us with his bicycle..
The savage 17mm adapters are not suited for the maxx, because the savage uses 8mm wheelshafts.
the phaltine wheels are COOL! i've seen them in person at my LHS, and they look stunning. Plain simple..
I know hobodies offers 17 mm adaptors for the maxx, (at least i thought it was hotbodies, they include them with wheels, i pressume their Ufo's etc.
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
10.01.2006, 06:52 AM
I used Savage hex's on my Emaxx for a while, it worked but was not ideal, if you don't want the wheels to fall off you gotta be careful shimming them a bit.
  Send a message via Yahoo to Rtsbasic
skellyo
skellyo's Avatar
10.01.2006, 08:48 AM
17mm adapters:
http://www.rc-monster.com/proddetail...Maximizer_2330
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
10.01.2006, 08:56 AM
Theres two types of 17mm, they look like adapters for buggy style 17mm? I use the other sort (like an oversized 14mm).
Serum
Serum's Avatar
10.01.2006, 10:11 AM
The maxximizer are the ones for the buggywheels
@aqwut, you can't center the savage hexes on a 6mm shaft. it's asking for a wobble.
skellyo
skellyo's Avatar
10.01.2006, 11:57 AM
Why won't the ones I listed work? They look like the same style as these, which are recommended by HPI for use with those wheels:
http://www2.towerhobbies.com/cgi-bin...?&I=LXKSC1&P=V
I realize the axle diameter is different between the two, but it appears that the flange on the hex adapter fits through the inside of the wheel hub on either set of adapters.
Serum
Serum's Avatar
10.01.2006, 12:03 PM
I thought the wheels he wanted to use needed other ones. (the savage X uses 17mm adaptors too, but they are simple 17 mm hexes, without the flange.)
Check this picture;
http://www2.towerhobbies.com/cgi-bin...?&I=LXNHV6&P=7
skellyo
skellyo's Avatar
10.01.2006, 12:11 PM
Read the text on this page regarding the Phaltline tires on Tremor wheels:
http://hpiracing.com/newparts.php
They recommend P/N 87229 for converting the Savage to 17mm, which are the hexes with flanges. I think the hub opening on the wheel is large enough for the flange, or you can use the standard Savage 17mm hexes which come with huge flanged washers that cover the hub opening.
Serum
Serum's Avatar
10.01.2006, 12:16 PM
Sounds fair to me.
Shadow350Z
Shadow350Z's Avatar
10.01.2006, 01:56 PM
ok i read everybodies post...
and im confused again... and these new RC lingos i missed i think
which do I need to use and like I can buy via local hobby shop
skellyo
skellyo's Avatar
10.01.2006, 02:16 PM
I believe you need the Maximizer products 17mm adapters. You probably will not find them at a LHS. Mike sells them though. You can find them in the link I posted earlier.
squeeforever
squeeforever's Avatar
10.01.2006, 02:32 PM
Forget the Maximizers....Go for the Ofna Adapters. There made for the Maxx's and for a 6mm axle and they don't use a washer and a locknut...They use a standard 17mm nut like it should be...
Shadow350Z
Shadow350Z's Avatar
10.01.2006, 02:42 PM
chaCHING thanks Squee thanks errbody
is it Ofna part #81175
squeeforever
10.01.2006, 02:57 PM
Yup...sure is...
