Ubec -
10.08.2006, 06:44 PM
Ok, so I hook up my UBEC finally and tested it out using the same exact configuration as before. It was working fine for about 1-2 minutes and then there was smoke. I removed the top as fast as possible only to find out my batteries were smoking badly and starting to explode. I unpluged the batteries right away and cooled them down. :013: :013: :013:
Anyway the problem is I don't know if it was the batteries which I have used before or if it was the UBEC from Koolflightsystems. I hooked up the black wire to the black deans connection and I hooked up the red wire to the red deans connection on the other battery. Then I pluged in the receiver connection. I am using two batteries in series. HELP - WHAT DO I DO? :007: :007: :007:
I don't want this problem to continue and more importantly i don't want to burn up any more batteries or anything else on the E-Revo for that matter. :026: :026: :026:
Equiptment - 20150 BK speed controller and lehner 1950/6 hi amp. Two six packs of gp3300 batteries in series.
